Returning mountain biker with two noob questions on current bikes...
Bikes: Cannondale SuperSix & CAAD9, Singlespeed Seven
Quoted: 5 Post(s)
I'd like to get back into mountain biking after not touching my current bike for over 7 years. It's a '94 Cannondale M800 with a pepperoni/beast of the east frame. Unfortunately, the components (all Deore LX) are in rough shape after years of hard use followed by neglect. I looked into replacing everything that needs replacing and upgrading to a front shock and that puts me in the ball park of a new cannondale hardtail (I'm not bike savvy, so my lbs would be performing all the work).
So, I have two questions:
1 - Are the current cannondale hardtail frames (Furio-X) better (lighter/stronger) than my frame?
2 - I may make the leap to full suspension - does the rear suspension have specific maintenance requirements or would it be as painless to own as a hardtail? All I know is hardtail, so I wouldn't know what I'd be missing performance-wise if I stick with hardtail (and the wife would be happy with the extra $$$ in my wallet )
I drink your MILKSHAKE
Bikes: 2003 Specialized Rockhopper FSR Comp, 1999 Specialized Hardrock Comp FS, 1971 Schwinn Varsity
No
Bikes: 2010 LHT, 2019 Kona Rove NRB, 07 Nashbar 853 Signature, Sundeal V2 mini velo, 1991 Fisher HKII
upgrading the fork may not work with the older frames geometry. you could end up with a raked out fork and chopper effect.
you will kost likely more bang for the buck if you decide to go hardtail rather than FS. For the same money you should get better components, better frame material and, higher quality construction. That being said, it depends on what sort of riding you want to do. Also, I have never used a FS bike. I just upgraded my old hardtail to a new one by moving components over to a new 853 frame and used (but new to me) marz fork. It's no freeride bike, but its great for heavy technical xc.
Quoted: 5 Post(s)
I had hoped this was the case, but I wasn't sure if the "good" frame technology was being saved for the full suspension bikes - just wanted to be sure.
Cool, good info
I would say you'd be better off with a new bike or slightly use one. Take a look at everything you can in your price range and look for reviews on the parts and components on the bikes you liked the most.
