Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Source for trackrings and cogs
Old 07-22-07 | 06:47 PM
Witness Protection Prg.
Looking for an online source for rings and cogs. Seems the only thing my LBS carries are the ultra-expensive rings and cogs. Buying them individually, I'll end up with a set of rings and cogs that are worth more than the damn bike?!? Can someone suggest a place to pick up a set?
Incognit0 is offline
Reply
Old 07-22-07 | 07:13 PM
chainrings are pretty expensive...
cassette is offline
Reply
Old 07-22-07 | 07:15 PM
CrimsonKarter21's Avatar
Mitcholo
Bikes: 2010 Mitcholo w/ Sram Force/Red
There's some kind of deal just above the groups, 2 Sugino rings and a full set of D-A cogs for $185. The best deal you can get unless you work in an LBS.
https://www.worldclasscycles.com/Track_components2.htm
CrimsonKarter21 is offline
Reply
Old 07-23-07 | 07:07 AM
fixedpip's Avatar
asleep at the wheel
Bikes: Custom Richie Ditta Track Bike, Eddie Merckx Corsa, Marioni Custom Pista, Dolan Cyclocross
I assume you're located in the US so https://www.businesscycles.com has a lot of really good stuff. They're not the most competitive on price but it but are a pleasure to deal with.
Chainrings as previous poster has noted are expensive esp properly round 144 bcd ones. But they'll last for ages and you can often recoup a lot of your outlay in the second hand market.
Ebay and Craigslist often pop up some good deals if you know what you're looking for.
fixedpip is offline
Reply
Old 07-23-07 | 07:23 AM
I actually found that site last night doing a search for track components. I notice they have:
# FSA
Track 1/8" (black anodized)
45, 46, 47, 48, 49, 50, 51, 52 - $39.50
Is there anything wrong with these rings? Cheapest rings I saw at the LBS were over $90 per ring. This looks like it will be a little easier to swallow.
Reply
Old 07-23-07 | 01:38 PM
# FSA
FSA rings are fine. I'd just suggest that you put any new chainring you get on your crankarms, mount a chain, and be sure the chain tension is pretty consistent throughout the rotation of the crank. It's hard for anybody to ride enough to wear out a 1/8" track chainring, but many of them out of the box do not have perfectly concentric mounting holes so the tooth circle is effectively out of round. If that's the case, return it. If not, they will all do well for you. Dura Ace have a slightly better finish on their current 7710 versions, and Sugino Zen (track, not the black messenger version) are particularly accurate and round, but they are nearly all interchangeable (just be sure you have a 144 BCD) and do the job just fine. Tooth profiles are sometimes slightly different but that's largely a marketing thing and less critical on the chainring anyway -- if your teeth are not optimal to begin with, the chain will take care of that within a month or so.
11.4 is offline
Reply
Old 07-23-07 | 02:33 PM
Bikes: Bianchi, Trek, Another Trek, Raleigh, Fuji and Santana and another Santana
I built up a good collection of chainrings (mostly campy) and cogs (mostly DA) on ebay.
Just my $.02
Pista Largo is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
