Lugged Steel Frames?
I'm mildly curious about something, namely: how exactly are lugged (steel) frames assembled?
I assume the lugs are welded somehow, but am not really sure how you'd put the whole thing together.
And no, I'm not going to try this at home.
I'm merely wondering how they're made.
Ok, so do you coat the end of the tube with a little bit of solder, hit the lug with the flame, and the solder melts & forms the bond?
I assume you also need to clean up the lug after that? Or do you just paint over it.
(FYI I've done a little bit of brazing in my time, nothing remotely like building a frame though.)
Bikes: Dawes Kalahari, Puch Prima Super Sport, Graham Weigh 853
Most British builders use brass solder rather than silver solder. Some, like witcombe, set up all the joins, then do the whole lot in one fell swoop in a furnace.
Decrepit Member
Bikes: Waterford 953 RS-22, several Paramounts
