When to do the dollar bill thing in a tire?
Rookie question... I got a flat from one end of a small carpenter's staple. Put in a new tube. Inspected inside of tire but didn't find the hole. After reassembling and pumping up the tire to 120 I see the hole on the outside. It's a straight hole, not a slit like from glass and it doesn't bulge at all at that point. Is there a high, medium or low risk of that hole pinching the tube in the inside? What's your guideline for when you a) do the dollar bill thing to protect the tube or b) go to a new tire? Thanks in advance.
Bikes: Homebuilt steel
Quoted: 2193 Post(s)
Liked 425 Times
The dollar bill thing is only to get home. It's not a long term fix.
Hard to say about the hole you describe. A photo would help. Most likely you will be fine.
Klaatu barada nikto
A much better solution (now that you're thinking about it) is to take a defunct tube and cut a 1x3" piece out of it. Stash it in your repair kit.
Fondriest Fanatic
Bikes: 2002 Fondriest Lampre Carb Level, 2004 Fondriest Top Level, 2004 Fondriest Status Plus Rossa SAT, 2000 Viner MR Alu Evolution, 2002 Cane Creek cyclocross team bike
hi all,
i did the dollar bill trick a while back with a puncture from a piece of glass. a fairly straight-on hole that i could see cord damage in the cut. i finished fixing the flat and rode comfortably for 30 miles to return home without incident. if it had been a larger hole or a gash, i wouldn't have been as confident.
have fun,
aaron
have fun,
aaron
Really Old Senior Member
What does using a $ Bill do that using a patch on the inside of the tire won't?
Curious minds want....
Liked 7 Times
Nothing and it can cost you a dollar. The only reason to use a dollar bill is if you blow a hole through the casing on the road and don't have anything better to use as a temporary boot. I carry a 3" section of inner tube to use as a tire boot. A hole in the casing part of a tire that is 1 mm or bigger probably needs a tire patch of some kind. A small puncture like from a goathead spine does not.
crusty
Bikes: Giant Kronos, Miele Appolo, Miele 12 spd, Diamondback Hybrid
Light Makes Right
Bikes: Gianni Motta Criterium, Dean Hardtail
I carry a chunk of duct tape backed by wax paper to use as a boot.
When I was a kid I once rode on a tire for a year like that - LOL
Single Speed freak
Bikes: Specialized Langster 2008, Saracen Morzine 2006, Gary Fisher Wahoo 2007, smith and wesson patrol
Guest
Posts: n/a
Quoted: Post(s)
I used the dollar bill trick when the tire casing separtated from the wire bead!
The blowout occured at the TOP of a big, fast descent. The $1 bill held throughout the descent (30+ mph) and the remaining 4 miles back to my car. Granted, I only had about 35 lbs pressure in the tire to keep the dollar from blowing out.
But it held as long as I needed it to. Now all my patch kits have $1 bills in them!
Listen to me
Mylar energy bar wrappers are cheaper and contain tasty treats.
I have had a Mylar boot in my rear tire for several months now, since I hit a rock that cut the sidewall, with no problems 700cX23 @125 psi.
What ever you use it needs to be flexible but not stretchy
Mylar wrappers are my other method. I like the idea of cutting up my old tube and using strips, but those pieces would be much thicker. I guess not a problem since ya'll do it.
I've also ridden for several hundred miles with a dollar bill covering a small slit from glass shard and no problem. Sounds like most of you would only do that temporarily.
Open question is... Would anyone ride with that little hole that I described or is that a sure-fire 'nother flat?
Bikes: Bruce Gordon BLT, Cannondale parts bike, Ecodyne recumbent trike, Counterpoint Opus 2, miyata 1000
I booted with a $1 and took 2 miles to get home. Wear on the bill was obvious. When I was having more problems with flats I would carry a section of tubular tire to use as a boot. never needed it.
cyclist/gearhead/cycli...
Bikes: Homebuilt tourer/commuter, modified-beyond-recognition 1990 Trek 1100, reasonably stock 2002-ish Gary Fisher Hoo Koo E Koo
If this hole is small and doesn't bulge, then it's not going to be a problem (some of my tires must have dozens of tiny pinpoint holes from thorns). This is because you have likely only punctured the rubber and not damaged the cloth matrix, so the tire hasn't lost any strength. If it appears that the hole is getting larger, it means you've damaged the cloth/cords that make up the strength of the tire... and it should be replaced. Fortunately, most puncture flats don't do this kind of damage in my experience.
Bikes: Cervelo, Pinarello, Specialized
Lowest bill we can use is a $5.
Pretty hard to boot a tire with a few of these:
or
or
Mr. Dopolina
Bikes: KUUPAS, Simpson VR
Quoted: 149 Post(s)
Liked 117 Times
I always carry a tire boot in my seatbag. The best boot is one cut from an old racing slick. You also need to cut the beads out as they cause a seating problem if left in. I have ridden 50+km with a boot in my tire and never worried about it.
I highly recommend carrying a boot with you. If not for your own use, then for your buddy who slices their tire on a group ride. Man, do you ever look like a genius when you sidle up to a bunch of dumbstruck riders all starring down at the gash in buddys' tire and you whip out on of these babies.
Blue Light Special
Bikes: '05 Felt F55, Schwinn Prologue road bike, '86 Centurion DS Iron Man, Sette Flite AM MTB
So that's, what, 100 pesos? 30 rubles?
