rim tape (11) on Mavic Open Pro
Bikes: 2004 Giant OCR, 2002 Specialized Stumpjumper, 2008 Trek 6500 Disc
I got my new wheels, Mavic Open Pro; however the rim tape I ordered, it looks like may not be wide enough. The rim tape is 11. It covers the holes but on some of them you can still see the outside diameter of the spoke hole. I went on a 20 mile ride this morning and I did not have any problems. I was wondering if I need to get wider rim tape or if this should be sufficient. It looks like the best would be either 17 or 22 for the size to cover all the areas. Any help would be appreciated.
Quoted: 1572 Post(s)
Liked 643 Times
Yeah, you need 17mm rim tape. If you don't change it it's just a matter of time before your tire's air pressure forces the inner tube against those sharp spoke holes and cause repeated flat tires.
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
This kind of flat sometimes takes some time to occur, but when it does it's always at the worst possible time!
Today, I believe my jurisdiction ends here...
