How often to replace chainrings?
Chain and cassette are shot - replace chainrings too?
I waited a bit too long to replace the chain on my commuter, and now both the chain and the cassette are shot. They're not so far gone that I can't ride on them until replacement parts arrive (i.e. no skipping, yet), but the chain-wear gauge does fall rather easily into the gap.
So...question: Do I need to replace my chainrings along with my freewheel? The bike is a double, but I use the big ring almost exclusively.
I don't know. I've never changed chainrings on a bike unless they were rendered useless by a crash or something. I just upgraded a bike and used an old shimano 105 crankset with chaingrings that were probably 10+ years old and they work just fine with a new cassette and chain. The same is not the case with a worn cassette and a new chain, you get slippage. My experience is that nothing will happen if you stick with the old rings.
Chainrings and casette wears down because of the chain. Replace chain, SRAM with EzLink. Then take your chain off every 100 miles or so and wash it well.
It's clean when you feel no sand or dirt inside the chain, when you take it in both your hands and bend it side to side slightly. When dirt you'd feel like there is dirt inside the chain. Clean until it feels like brand new chain. Then lube.
Cross chaining, bad chainline, cheap chainring are also factors.
Pwnerer
In my experience, chainrings wear about two to three times slower than cogs and chains.
The torque load is distributed over a greater number of teeth, and on a double, you are not "shifting through" any chainrings as with a triple. With triples the middle chainring seems to get the most abuse as you can't skip over it to go from large to small, or vice versa.
I'd replace the cassette and chain, then replace the chainrings if necessary.
Thanks for the feedback. I'll probably go ahead and replace the chain and cassette, and see how things go.
I will attempt to procure replacement chainrings in the event that they are needed. I need 144mm BCD rings though, which all seem to sell for big $$ (at least, bigger than I want to spend on a commuter bike). Argh.
Pwnerer
Good call.
I can't say you won't need the chainrings. A client and friend of mine that is a high-mileage roadie replaces cassettes and chains together nearly every year, and chains inbetween cassette replacements. He'd never replaced his chainrings and when I recently installed some new Salsa rings, he came back and said his front shifting was better than it'd ever been before, even when new.
At least you can spend some time now to find a deal on the chainrings.
Chainrings last a long time, especially if you change the chain regularly. Eventually, you will see that the CR teeth look shark-finned, that means they are starting to wear. Sure fire way to determine is to put a new chain on and if you hear noise from the CR, time to replace.
I've had chainrings last 10 years+ with regular riding.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
Quoted: 2026 Post(s)
Liked 1,095 Times
Bikes: Giant TCR Comps, Cdale R5000, Klein Q-Pro, Litespeed Siena, Piasano 105, Redline Conquest Pro, Voodoo Bizango, Fuji Aloha
Cries on hills
Bikes: 2007 Trek Pilot 1.2, 1969 Raleigh Sprite 5
Quoted: 83 Post(s)
What about shifting ramps? Or whatever these are called: I've looked at the Alivio crankset on my bike, and there are these notches running down some of the valleys, in four locations. The notch is flared a bit, presumably to help the chain ride up on upshifts (this is an MTB, so big jumps). The teeth near there look very shark tooth, but the rest just look somewhat worn. I have ridden the bike with a very worn chain in the past, and the current one is worn out also (but not as badly).
Pwnerer
All that was related was experience. Chainrings last a lot longer than most people think...apparently including you.
And yes, my telepathetic powers are formidable.
Bikes: 2010 Tarmac SL, 2013 Fairdale Weekender, 2013 Fairdale Coaster, 1995 Specialized M2 Pro, 1972 Schwinn Heavy Duty, 2014 Surley Long Haul Trucker
I'm not sure why there's attitude seeping in from all corners, but it doesn't help anything.
The chainrings don't look worn. They're only one chain old, so to speak (and the small ring has barely been touched - I may replace it with a bigger one eventually). I did once ride a drivetrain on another bike right into the ground - the jockey wheels were so worn that the tips of what once had been gear teeth were needle-sharp! By comparison, my current commuter is newer-than-new
A tangentially related question - does cross-chaining increase wear on chains/cassettes/rings?
Elite Fred
Bikes: 2009 Spooky (cracked frame), 2006 Curtlo, 2002 Lemond (current race bike) Zurich, 1987 Serotta Colorado, 1986 Cannondale for commuting, a 1984 Cannondale on loan to my son
Quoted: 60 Post(s)
Liked 42 Times
Bikes: Giant Defy Advanced 1, Trek Madone 5.0, Trek 5400
There seems to be some debate concerning chain ring replacement. Can anyone post a photograph of what they consider replacement worthy wear or damage? I'm considering replacing my outer ring on my Madone 5.0 commuter (and backup). Having some difficulty finding a replacement. It is a triple crank, 52 tooth. Can it safely be replaced with a 53 tooth ring?
Liked 1,095 Times
Crank makers typically design their chainrings in pairs so the shifting enhancements (ramps, pins, shaped teeth) line up for best results. Changing to a chainring from a different set will compromise shifting somewhat. So, using a 53T chainring intended for a 39T small ring will not shift as well as the matched 52T that is provided on a triple crank.
Quoted: 5766 Post(s)
Liked 2,538 Times
like tires, brake shoes and cables, there's no scheduled replacement involved. Replace as needed. Meaning when the chain slips and won't transmit power, or when teeth break or bend. On a road bike, this may happen at 40-50,000 miles or so. On a mtn bike the granny or middle ring can wear out in less than a year of hard riding.
FB
Chain-L site
FB
Chain-L site
