Damaged Crank, Replace only one arm?
Ride the Road
Bikes: Surly Cross-Check; hard tail MTB
Liked 5 Times
One of my cranks is damaged. It was creaking, and two days in a row, I tightened the bolt after my commute home, and two days in a row, it was loose the next day. Today, I tightened it 2/3 of a turn.
The LBS sold me a crank puller to take a look at it (I prefer to buy the tool instead of the labor, especially since advice comes with MSRP). The mechanic said that if the problem was the crank arm, I could just replace the one arm. Well, I pulled the crank, and it's worn on all four sides of the opening.
I notice that online places only sell crank sets. If the LBS can match come close or match the original crank, is there any problem with buying only one crank arm?
I ride a lightly-loaded Surly Cross Check for commuting every day.
Batteries not included.
As long as you find a matching arm, there's nothing inherently wrong with just replacing the one arm. The only problem is, it's usually quite difficult to find a matching arm, or at least at such a price as to be worth it versus replacing the whole crankset.
Extra Medium Member
When you say "matching arm" are you referring to the length and Q-factor? Other than that, you can use whatever crank-arm you want as long as it fits the type bottom bracket you use.
Ride the Road
Liked 5 Times
As long as I had the right size and generally the same weight, would I even notice on a loaded steel commuting bike?
Quoted: 1572 Post(s)
Liked 643 Times
Replacement left crankarms are a common repair part. For a bread and butter crank you should be able to get one that's a reasonably close visual match for $20.00.
The thing is, replacing a crank arm - if it's of a different make, probably won't match. I tried it last month, at least for square taper arms different - makers put the hole at a different angle. So it's impossible to get them parallel to each other. It's hard to explain without pictures.
JRA...
Bikes: trek 520 & 736, DeRosa Professional, Fuji Professional, Raleigh International 3-speed, Saronni (any info people?), Humber 3-speed, Raleigh Sports, Carlton Grand Prix coming soon!
what you will find is that the q factor on a basic replacement arm may vary greatly from that of the original.
Listen to me
Unless the crankarm is cracked you can salvage it.
Typically the crank arm bottoms out on the flared portion of the spindle (where it goes from square to round). If this is the case you can rework the crank to remove some material from the crank arm in this area. The two options would be to add a generous chamfer on all four sides of the spindle hole (flat file or dremmel) or to remove material (1/8") from the inside face of the crank (grinder or hacksaw).
The intend is to allow the worn crank arm to slide further up the taper to a point where it is making good contact with the taper.
I have done both methods on seperate bikes and have had no more loose crank issues on either.
Ride the Road
Liked 5 Times
I like DIY bike repairs, but reworking the crank arm seemed like more than I wanted to do. So I bought the $15 arm. The LBS offered to use their pedal wrench to loosen my pedal (so I could use my cone wrenches to complete the job at home), but they couldn't get it loose. They even took the pedal off and put it in a vise.
So I'm buying new pedals. Fortunately, I was looking at getting new ones anyway. The advantage of paying MSRP for the crank arm, crank puller and pedals is that I get exactly what I need and some free labor. Not bad. (Oops, I forgot to have them see if they could get my left pedal off!)
Your mom
I think if you're crank arm's damaged, your BB spindle probably is as well. I'd replace it all, especially since BB's are only ~$25. But yes, you can replace just one arm, you just have to find one.
Mechanic/Tourist
Unless it's a steel arm, which would occur cheaper bikes, the aluminum arm will wear long before the steel crank spindle. I replaced many, many left crank arms in my life and have not seen a problem with them not mating and staying on the used spindle.
