Pre-Flight Checks
Peddlin' Around Detroit
Bikes: Legend, Saluki, Trek 730
Pre-Flight Checks
Okay, pre-biking checks. I've discovered two pre-checks which would be a good idea to do:
1. Got Water? I have a couple of water bottles for the bike frame, and I either:
A. Take off with the water bottles empty ... but in the water bottle cages. Or ...
B. I have the proper planning to grab the bottles, fill them with cold water and put them in the freezer just prior to hitting the road ... and hit the road with the water bottles still in the freezer.
2. Check the brake cables ... and brake caliper opener thingie (that you open to remove front wheel). I've always favored my rear brake, which explains why I've made two 15 mile rides with the front brake caliper thingie wide open ... meaning no front brakes while zipping down hills at 20 MPH.
What else are good pre-biking checks when going out for a 2 hour ride from your house? And would there be different pre-biking checks you would do based on the temperature (100+ degree heat index this week), the season (Michigan winters), and metropark-MUP rides versus road rides?
I need more cowbell.
Bikes: 2015 Specialized Sirrus Elite
Quoted: 23 Post(s)
Here's a few
ID on board?
Cell phone?
Is the bike bag closed and zipped up tight? (Learned that one from Granny Gear)
ID on board?
Cell phone?
2015 Sirrus Elite
Proud member of the original Club Tombay
2015 Sirrus Elite
The guy in the 50+ jersey
Bikes: Specialized S-Works Roubaix, Litespeed Tuscany Road, Specialized Allez Epic lugged carbon frame Road,Giant Anthem 29'r, Klein Hardtail
Nutrition of choice for rides over 1 hr.
HomeBrew Master!
Bikes: Aegis Aro Svelte, Surly LHT, Cannondal R3000 tandem, Santana Triplet.
The Grampster
Bikes: Eddy Merckx SXM, LeMond Buenos Aires, Cannondale Road Warrior 1000 plus a couple of comforts (Specialized Crossroads and Giant Cyprus) and a beater mtb for around town.
I can remember my big 4: Cell phone, wallet, sunglasses, keys. Everything else I need reminders on. So, I refill water bottles and put them in the fridge...then I hang my gloves on the bottle cages so I'll remember the bottles. Wrap my HR strap around the handle bars to remind me to attach the Garmin. Zip lock bag with bar, banana and a couple of gels. Now if I just had a sure way to not forget my shoes.
The definition of insanity is doing the same thing over and over and expecting different results.
--Ben Franklin
--Ben Franklin
Time for a change.
Liked 5 Times
It is surprising how many times I go out without some vital part of the bike or cycling gear.
Helmet always has gloves and glasses in it so those 3 will always go with me. On the bike are a tool bag that never gets taken off and I have one for each bike--The same with the pump. Computer is normally taken off the bike after each ride and is left indoors somewhere but is never forgotten for some reason. Water bottle always stays on the bike- Only one but after each ride- it is taken in for a wash and an empty one put in the cage- upside down. If it is a longer ride than normal then the Camelback gets taken on the ride and that is always a problem. I rarely use it on the road as Cafe stops and shops are handy for fresh water. But that camelback needs a thorough clean after use and I always forget to clean it. so it is a 1 hour wait while the Disinfectant gets to work if I want to use it.
So all those tips so that I never forget anything and the water bottle is often left upside down and empty. The repair kit in the tool bag is often left in the shed after I repaired a neighbours tube-and the same with the pump as I used that on the repair. Computer is never forgotten but I often have to use one off another bike as I can't find the right one. And I often can't find the camelback as last time I used it- The wife put it somewhere- instead of in the lounge where I left it to remind me to clean it out and Even she forgot where she put it.
Now when it comes to pre-ride checks- I always do it after a ride when I check the bike over- Other than Pump up the tyres with the track pump- the bike is always ready to go. Just a pity my Brain isn't.
Spike Milligan
Spike Milligan
Bikes: 2008 Specialized Roubaix Elite Compact, 2004 Giant Cypress, 1981 Specialized Sequoia
You've convinced me to post a pre-ride checklist on the wall above where I store my bike. Thanks!
The Grampster
NadaKid
Bikes: Schwinn Traveler, Giant Cypress
When the wife goes with me on a ride she gets mad at me for "taking forever to get ready" but guess who gets to fix her bike if something goes wrong.
Software for Cyclists
Bikes: Trek 5200, Specialized MTB
"ABC Quick Check", per the League of American Cyclists:
1. A is for air
* Inflate tires to rated pressure as listed on the sidewall of the tire
* Use a pressure gauge to insure proper pressure
* Check for damage to tire tread and sidewall; replace if damaged
2. B is for brakes
* Inspect pads for wear; replace is there is less than ¼" of pad left
* Check pad adjustment; make sure they do not rub tire or dive into spokes
* Check brake level travel; at least 1" between bar and lever when applied
3. C is for cranks, chain and cassette
* Make sure that your crank bolts are tight; lube the threads only, nothing else
* Check your chain for wear; 12 links should measure no more than 12 1/8 inches
* If your chain skips on your cassette, you might need a new one or just an adjustment
4. Quick is for quick releases
* Hubs need to be tight in the frame; your quick release should engage at 90°
* Your hub quick release should point back to insure that nothing catches on it
* Inspect brake quick releases to insure that they have been re-engaged
5. Check is for check it over
* Take a quick ride to check if derailleurs and brakes are working properly
* Inspect the bike for loose or broken parts; tighten, replace or fix them
* Pay extra attention to your bike during the first few miles of the ride
1. A is for air
2. B is for brakes
Surly Girly
I think all the essentials have been covered, but I also put on sunscreen before every ride. It protects my arms from sunburn and assures that I'll return home just as pale as when I left.
Specialized Roubaix Expert
Surly Long Haul Trucker
staring at the mountains
Bikes: Obed GVR, Fairdale Goodship, Salsa Timberjack 29
Quoted: 394 Post(s)
Liked 197 Times
I learned this little routine from when I taught skiing (leaving a piece of ski gear behind is, um, worse?):
* Point to parts of your body, from feet up to your head:
shoes, socks, shorts, jersey, gloves, sunglasses, helmet. check.
* each pocket of the jersey (left to right for me)
nutrition; tube, pump (I wear mine, a Crank Bros), tri-spoke allen wrench and balled up rain jacket; cellphone, wallet, keys
* do the same with the bike:
air in the tires, saddle bag, water bottles (filled!)
Bike Junkie
Location: South of Raleigh, North of New Hill, East of Harris Lake, NC
Bikes: Specialized Tarmac, Specialized Roubaix, Giant OCR-C, Specialized Stumpjumper FSR, Stumpjumper Comp, 88 & 92Nishiki Ariel, 87 Centurion Ironman, 92 Paramount, 84 Nishiki Medalist
Quoted: 68 Post(s)
Liked 37 Times
I havn't seen anyone list a spare tube and pump or CO2 canisters. Maybe I missed it. Additionally I ALWAYS pack a Topeak multi-tool with chain breaker, Presta adaptor and 4" folding knife.
Roccobike BF Official Thread Terminator
Bikes: Trek 5500 OCLV, Trek Fuel EX 9
I thought I was the only one who takes forever to get ready for a ride. I think you guys have covered most of my list except sunglasses or other eye protection. And did anyone mention gloves yet?
Nevermind, I see stapfam and Superdex have it covered...
Liked 12 Times
It is usually totally ready to go, and it has toe clips. So, I can jump on it wearing whatever I might have on - regular shorts, sweat shirt, Levis in winter, whatever, including tennis shoes, and just pedal away. The only requirement is one rubber band on the right pants leg (I keep losing those thingies that are made just for that purpose, so I just have a large box of rubber bands.)
It has panniers so I can go to the grocery store and get stuff, etc.
Sometimes it just takes too long to get all duded up! Fast is good.
But make sure you're cat (aka: The Gremlin) is not in the area. My new bike came with cool transparent presta valve caps. Aired up one tire, then the next, and poof: one of the valve caps was stolen by Smokey the Gremlin. My money is betting that the transparent valve is now in one of the black holes within the basement ... never to be seen again.
How mission-critical is it to have the valve caps on the wheels? For riding off-road through bushes, it's probably mandatory, but what about on-road riding?
In the case of Presta valves, which have non-removeable, built-in caps, external caps are unnecessary in use. The purpose of these redundant caps that come with Presta tubes and tubulars is so that the pointy end of the valve won't puncture your spare tube or tubular while it is rolled up. There's no reason to use them in actual riding
Turn my cell phone to vibrate only. I hate riding along and having the phone ring. I'd much sooner have it vibrate so that I can discretely pull over to the side, look to see who is calling, and either answer it or not without others knowing I've ogt someone calling me.
