Go Back  Bike Forums > Bike Forums > BMX
Front Heavy
BMX Dirt, vert, flatland or street? Drop in the BMX forum to talk to other 20" riders around the world. What is the best BMX bicycle for you? Learn all about it here.
Front Heavy
Old 08-06-07 | 12:57 AM
CamHat's Avatar
Front Heavy
When you first started riding a proper bmx bike did the front seem heavy to you? Because it does for me. It is hard to get it up high enough to bunnyhop higher than 3 inches. Does anybody have anytips on this?
CamHat is offline
Reply
Old 08-06-07 | 01:39 AM
fuzzbox's Avatar
Your imaginary friend.
Bikes: A sweet Quamen ATL custom, GT Mach 2
it was more like back heavy to me. you should try crouching down and popping up if it makes sense
Every passing minute is another chance to turn it all around.
fuzzbox is offline
Reply
Old 08-06-07 | 04:33 AM
callumrides's Avatar
Coast Freely
Bikes: bmx
practice doing wheelies without pedaling. then start trying to level the bike out. bunnyhopping isn't just a matter of lifting both wheels at the same. you need to lift the front then level out with the back.
callumrides is offline
Reply
Old 08-06-07 | 09:52 AM
live4muzic2's Avatar
BMX Veteran
Bikes: gt mirraco redline torker2 magna mini
can you post a picture of your bike from the side? your bars may be at the wrong angle.
live4muzic2 is offline
Reply
Old 08-06-07 | 10:59 AM
CamHat's Avatar
i will post a pic later today
CamHat is offline
Reply
Old 08-06-07 | 12:47 PM
CamHat's Avatar
Here are the pics.
I like the Kink bike even though most of you will say its crap. i got a good deal on it and a warranty for free. And it is 1000 times better than my old bike below that i found in the street. Then i added some stuff to it.
CamHat is offline
Reply
Old 08-06-07 | 01:29 PM
FitRider 921's Avatar
I rule with a mighty leg
Bikes: Fit Pro custom
If you angled the bars a little bit further back, the front end may seem a bit lighter.
I am Gunz. Gunz are me.
FitRider 921 is offline
Reply
Old 08-06-07 | 01:32 PM
CamHat's Avatar
aight thanks fit
Wait fit, do you mean pull them towards me or push them away from me?
CamHat is offline
Reply
Old 08-06-07 | 02:03 PM
Pull them towards you, but just a little bit.
Reply
Old 08-06-07 | 03:33 PM
CamHat's Avatar
Wow Fit. That did the trick. I know can lift the front WAYYY easier to lift the front. It was such a simple thing that i did not even think of.
CamHat is offline
Reply
Old 08-06-07 | 03:59 PM
Yeah, I'm glad that worked for you. It would be really nice if that frame was cromoly.
Reply
Old 08-06-07 | 04:08 PM
CamHat's Avatar
Hey, it should be alright for a person getting into bmx right? I won't be doing anything huge until i get better which will take a while. You think it will last me a while? It was one of the only bikes that i could afford and i really wanted to get into Bmx. I knew it was 1020 hi-ten when i bought it. It feels nice and i like it. But, it should be good for a begginer right?
CamHat is offline
Reply
Old 08-06-07 | 04:16 PM
thermo's Avatar
nuB flatlander
Bikes: Hoffman Disrupter
So long as it isn't a Wal-Mart bike it should hold up fine for a beginner.
I've never thought of putting the bars back at an angle for bunny-hopping. I should try it I think.
thermo is offline
Reply
Old 08-06-07 | 04:17 PM
CamHat's Avatar
I think that Mongoose is a Wal-Mart Bike. The kink is from my LBS.
CamHat is offline
Reply
Old 08-06-07 | 04:22 PM
You would think that. Unfortunately, cheap BMX bikes fall apart very quickly, and you will most likely find that to be the case. My rear triangle on my frame isn't full cromoly, and hence it is almost in two pieces on my grind side from learning how to grind.
Reply
Old 08-06-07 | 05:04 PM
thermo's Avatar
nuB flatlander
Although if he can only bunny-hop about 3", he probably won't be doing grinds any time soon.
thermo is offline
Reply
Old 08-06-07 | 05:28 PM
L!vE2R!D3's Avatar
Bikes: 2006 GT Compe
He could try Smith Grinds...if he finds something that is 6" high that is.
L!vE2R!D3 is offline
Reply
Old 08-06-07 | 06:44 PM
thermo's Avatar
nuB flatlander
Although if it is only 6" high he might not be able to grind it at all. His tires would be on the ground and his pegs an inch or so above the [whatever he is going to grind on].
thermo is offline
Reply
Old 08-06-07 | 06:47 PM
CamHat's Avatar
Speaking of grinding, what kind of pegs should i get?
CamHat is offline
Reply
Old 08-06-07 | 06:52 PM
thermo's Avatar
nuB flatlander
Metal, not wooden.
thermo is offline
Reply
Old 08-06-07 | 10:09 PM
BMX Veteran
duh, but a peg is a peg, it doesnt matter. but i like my new colony pegs, ligher than my bar ends.
Reply
Old 08-06-07 | 10:45 PM
Pegs do actually matter. If you don't think so, then I will gladly trade you my pegs for yours. Mine wear through extremely quickly and don't slide so well.
As for your question, get some Kink Lights, or be like me and wait for the G-Sport Plegs to come out.
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
