Go Back  Bike Forums > Bike Forums > Recreational & Family
Advent Allycat Hitch Problems
Recreational & Family Ride just to ride? Have a family and want to get them into cycling? Drop in here to discuss recreational and family cycling issues.
Old 08-06-07, 01:28 PM
oldskoolboarder's Avatar
I bought a used Allycat trail-a-bike. Unfortunately, the hitch seems to be made for a seatpost of some un-godly small size less than 1".
It uses a top and bottom collar that holds the hitch mechanism in place on the seatpost. I installed 1 collar and used an old inner tube to keep it snug. But this doesn't last long before it comes loose.
Is there any place that sells just the seatpost hitch? I'm will to try another vendor to see if I can salvage this trailer. I've seen Traileron but I don't know if that's sufficient to hold a trail-a-bike.
Suggestions?
oldskoolboarder is offline
Old 08-07-07, 10:51 AM
Trainingwheels's Avatar
I have one also. Using one collar is not tight enough? Have you tried using both collars?
Trainingwheels is offline
Old 08-08-07, 04:34 PM
Sorry, I wasn't clear. When trying to use both collars the inside diameter is WAY smaller than my 27.2mm seatpost. In fact, it looks smaller than 25.4, if that makes any sense. As a result, the outside diameter becomes so stretched that the hitch won't fit over it. I can't pry open the hitch big enough.
My kludge was to only use one collar but that's not stable.
Old 08-08-07, 07:10 PM
DieselDan's Avatar
Location: Beaufort, South Carolina, USA and surrounding islands.
Bikes: Cannondale R500, Motobecane Messenger
Quoted: 11 Post(s)
Pull the seatpost out of the frame. There should be a number with the symbol ø followed by a number. That is the seatpost diameter in millimeters. If you need to shim down the insert, cut an aluminum drink can.
DieselDan is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
