so, I stopped doing this in '88
and things are a bit different now. I have a few questions if you guys will help me out. I bought a cruiser and started racing again last weekend, and my issues are:
Why are the stock tires so big? 1.95?!? I looked around and everyone is racing large tires. Is it uncommon for me to throw the 1 3/8 on here?
why is my sprocket so small? This dk came stock with a 30 - I always used a 44. Is this normal?
Are people going to throw things at me if I put Pro bars on a cruiser? These feel a bit small with a 5" rise.
I'll keep quiet for the most part, glad to be here, and thanks in advance for any help.
BMX Veteran
Bikes: gt mirraco redline torker2 magna mini
whatever feels right is what you do. i get told to go brakeless but i dont since i have 100 dollar brakes. sproket size is pretty normal, but it doesent matter.
You should time travel back to '88 and have a good time there. Things have changed and you have to change too. Just get a bike and don't complain on how things have changed. Get used to it.
Dig.
Bikes: FTW, Gunnar Roadie, Open U.P, Gunnar Rock Hound, S&M CCR
thanks for the replies everyone.
given the option of time travel, I wouldn't want to redo any of the 80's.
- but I will probably go ahead and get a 40t chain wheel.
steel lover
Bikes: Bianchi Alloro, Miyata 710, Fuji Espree Fixie convert
Some spin some don't. With that said... different tracks require different gearing.... DK didn't know what track you were going to be riding on. They didn't know how long the straights were, or how long the whole track was. I too ran a 44t on my old Cycle Craft back in the day... but I mashed like crazy compared to the other riders. I prefered to carry the speed than to spin my azz off, brake hard, just to sprint again. I was better at taking high corners and powering through, or entering high, and cutting low using the berm as a down hill.... worked for me even if it wasn't "conventional" or the normal.
Bars... whatever you want. Heck, I road with mini bars on my GT Junior Interceptor, and I road (and still have) cruiser bars on my Cycle Craft 20in.
Tires... seemed to go by fads if I remember correctly.... honestly, lighter is better as long as you have plenty of sidebite... I only raced a select few races which were mud-fests and would benefit from a wider tire. Man were those fun.... unfortunatly I was on skinny Junior sized tires at the time... talk about "spinning" up the jumps... literally.
It's whatever works for you.
I race cruiser as well so will offer my opinion.
What size sprocket you run doesn't matter unless you are a weight weenie. It is the resulting gear ratio that matters. The gear ratio is influenced by your tires, sprocket and cog, most cruiser racers I know run somewhere between 54 and 58 gear inches. If you run a 44 on the front you would need to run a 19 tooth sprocket on the back to get in this range, I ran 44 * 18 for awhile, that gave me 58.5 gear inches with my 1.85 tires,but I was getting killed out of the gates. I now run 40 * 17 for 56.5 gear inches, I tried 39 * 17 but felt off balance with my feet going so fast. If you start messing with the sprockets and cogs you will need to either run a long chain and a tensioner (not a tug) or have numerous chains that go with each combo.
Tire size is a matter of preference. I like a lot of air volume as I am a terrible jumper/lander but a lot of the faster guys at the local tracks run 1.5's. If you go to the smaller tires then your gear inches will drop as well.
I tried the pro bars on my cruiser as I am 6'7" and felt wierd with the lower bars. The tall bars felt equally as wierd and made the bike feel twitchy. I have just put on some 6 inch rise to try out but that will have to wait as I broke a few ribs trying to learn to jump better.
Your imaginary friend.
Bikes: A sweet Quamen ATL custom, GT Mach 2
what exactly do chain tensioners do, i no its self explanitory but still...
Every passing minute is another chance to turn it all around.
Long haired freak.
Bikes: 2011 SE Old Man Flyer.
Pull the wheel back in the dropout usually by using an Hex key, just an alternative to prying the wheel back and can make it easier to set up the chain/wheel.
"the bus came by and I got on, that's when it all began...there was Cowboy Neal at the wheel of a bus to never-ever land."
that's good info andy. I'm going to have to research the gear ratio varialbles - I wasn't aware that tires affected anything more than drag. Thanks for your help.
Terminology issue with "Chain tensioners".
Some are as wethepeople indicated, they pull the wheel back in the dropout and keep it there. What I was referring to was a spring loaded one that has a pulley that your chain runs over, this type of tensioner takes up slack in the chain. Similar to the one in the link
https://www.pinkbike.com/news/YESS-pr...ners-2007.html
The beauty of this on a cruiser is that you can run a chain that is a bit long so that you are able to change sprockets/cogs without having to change the chain. It also makes tight spots in your driveline not a problem.
Tire size changes the gear ratio as the narrower tire has a smaller diameter.
Long haired freak.
Those are also known as a no-railer around here, kind of a play on derailleur.
niceeee now the shape of the ones i see make sense on where they go
