No quality nowadays
The Flying Scot
From: North Queensferry Scotland and London (and France)
Bikes: Custom (Colin Laing) 531c fast tourer/audax, 1964 Flying Scot Continental, 1995 Cinelli Supercorsa, Holdsworth Mistral single speed, Dahon Speed 6 (folder), Micmo Sirocco and a few more
No quality nowadays
As some of you might have gathered, I'm not a fan of Shimano parts (because of the global domination and restriction of choice resulting from their markleting) , preferring Campag if possible, and certainly a mix of what I consider to be the best bits for any one job.
At present the only Shimano parts on my commuting frame are chainring bolts, bought in an emergency because they were the only ones which fitted my Stronglight C/set I could get in a hurry!
The pedals on this bike were MKS GR8 pedals and I've just had to replace them as the creaking noise from the left one(which has been driving me daft for months, and which I've tried several times to fix and been successful for only short periods) was caused by a pit on the bearing surface.
Now, these pedals have been on my bike, and the one before it, for a period in excess of 20 years and goodness knows how many miles.
They would probably still be on the bike and performing faultlessly if I hadn't lost an end cap about a year ago and not been able to get a replacement.
Anyway, I've replaced them with you've guessed it..................................Shimano?
No, of course not! MKS GR9 pedals.
If these are ok I'll be looking to replace them in 2025!
plus je vois les hommes, plus j'admire les chiens
1985 Sandy Gilchrist-Colin Laing built 531c Audax/fast tourer.
1964 Flying Scot Continental (531)
1995 Cinelli Supercorsa (Columbus SLX)
1980s Holdsworth Mistral fixed (531)
2005 Dahon Speed 6 (folder)
(YES I LIKE STEEL)
2008 Viking Saratoga tandem
2008 Micmo Sirocco Hybrid (aluminium!)
2012 BTwin Rockrider 8.1
(YES I LIKE STEEL)
MKS do make replacement dust caps and cones, if you can find a shop to supply them . Im looking around for a source of MKS axles to replace some crash-damaged ones.
On the Shimano front, I will defend them for producing some fine dual pivot, long-reach brakes.
The Flying Scot
Thanks Michael, I had tried but the only dust caps I could get were for the GR9 not 8 and they wouldn't fit.
Typical tho' I mentioned to a friend this a.m and he says I can have his GR 8's as he's swapping to clipless!
(YES I LIKE STEEL)
(YES I LIKE STEEL)
Bikes: Seven Axiom Ti, Trek 620, Masi cylocross (steel). Masi Souleville 8spd, Fat Chance Mtn. (steel), Schwinn Triple Bar cruiser, Mazi Speciale Fix/single, Schwinn Typhoon
I once, in desperation used the plastic top of a Finish Line chainlube bottle, it was jus the right size to "snap in" and stay put, perhaps you could try the same with an old bottle top.
Ride ingenious
Pat
Ride ingenious
Pat
