Was this stem a good find for five dollars?
Bikes: Surly Cross-Check, '85 Giant road bike (unrecogizable fixed-gear conversion
115mm Threaded, 1"
It says "Record" on one side of the stem, "3ttt" on the other.
"mm115" on one side of the quill, "Italy" on the other.
The clamp bolt and the stem bolt seems to take a 7mm allen head.
I should also post this in the Classic and Vintage forum, but I'm more likely to get a response here.
Edificating
Bikes: Spooky + Sachs
3ttt record stem... ~$50
Purdy too.
Cat 3 // Dylan M Howell
It's not as shiny and pretty as that one. A little scratched up.
Bikes: Cruzbike Silvio, Cruzbike Mtb Conversion, Raleigh Technium (converted to fixie)
I have the same stem on my fixie. Looks nice, I'd say you did OK.
Mark
Mark
Edificating
All around nice guy
Bikes: THE KIND WITH TWO WHEELS AND ONE GEAR
Those stems are pretty nice but the wedge mechanism is weird, it usually gets stuck in the steerer. And I have also seen them split from tightening them down to hard.
For 5 bucks its totally good. $5 would be a fair or slightly high price for a crummy SR stem. Recently I got a nos-ish 3ttt stem for $20 and that was a nice deal. That 115 is probably how long the extension is in mm.
hello
The lower threaded portion of my steerer tube developed a buldge and a crack from that wedge. Just make sure the wedge mechanism is seated well below the threaded portion of the steerer tube.
Actually, I don't think it's going to work for the bike for which it was intended. It slopes downward and won't go up as high as the current stem. What I really need to do is spring for a Nitto Technomic.
It might work on my other fixed gear which has a very small frame. It would be super low, but at least the reach would be right.
