Front coaster brake?
ǝıd ǝʌol ʎllɐǝɹ I
Ok, so my cargo/porter/rat bike has a broken canti braze on post thing, there's a 1/2 v brake on the left side for looking class, but it has no front brake to speak of.
Of course a drum brake would be cool but I don't own one. I do have a 36 hole coaster brake though, and I seem to recall these things take a lot of force to get any useful braking out of. I've seen that thread with the bike with the suicide brake thing, looks really class but would a coaster brake be workable with a V brake lever?
holyrollin'
I don't know how to actuate a coaster brake except via the chain. I think there might be a need for mechanical advantage here, as the cranks act as lever arms on a coaster brake.
ǝıd ǝʌol ʎllɐǝɹ I
Well yeah obviously I'd have to make something as seen on drum brakes, what I'm wondering is if it would work reasonably well given a v brake lever and fingers to pull it. I seem to recall having to put a lot of weight on the pedal to get any useful braking out of said brakes, but that was a long time ago, and back then I was also much smaller/lighter.
*****es love tarck
Bikes: so many
gravity speed freek
Bikes: too many
thats a cool idea, but i agree that a hand lever would not have anywhere near enough travel to actuate the coaster brake. i made the suicide brake bike, and there is alot of distance covered when i pull back on that handle to brake. your on the right train of thought though, thinking out of the box is a great start.
since you only have one brake boss how bout this, mount the brak arm and hand lever and instead of a brake pad, mount a hand with a certain finger extended, that way when you pull the brake lever you can "waive" to the cars that arent giving you your lane.
maybe use the brake boss to mount a light.
maybe use it to mount a really long antena w/ an orange flag on the end like the big wheels when we were kids.
i look at every hole in any part of any bicycle as a place to mount something.
fast eddie outty
fast eddie outty
Bikes: Rustbuckets, the lot of them.
I saw an odd front hub for sale on ebay once that was essentially a coaster brake hub, with a brake arm and a lever that went where the sprocket normally goes, intended to attach to a handlebar lever. ISTR it was a Bendix.
I think something can be hacked out of a normal coaster brake hub. A lever could be brazed onto an existing sprocket, with several holes for a cable anchor. Several holes may be needed for experimentation determining the proper amount of leverage needed to engage via a given brake lever. The hardest part would be setting the hub innards so that not so much travel is needed to engage the braking action.
ETA: You would also need some kind of spring to keep the sprocket/arm normally in the "disengaged" position.
ǝıd ǝʌol ʎllɐǝɹ I
I've installed the wheel that I'd laced with the coaster brake wheel on another bike, turns out it takes much less presure then I recalled, also the travel between freewheeling and brake engagement is less then I expected, but it's not an on or off thing with pressure determining braking force, there's some more predal travel between brake engaged and hard braking. So I dunno if this is truly doable, of course having yet to see even a single coaster brake used this way says alot about it.
Unfortunately, it seems I've ruined the bike in need of a front brake due to lack of same... So I won't be persuing this project. In any case thanks for the insight, I appreciate.
Damage on the bike in question can be seen here:
https://bikeforums.net/showthread.php?t=333507
Bikes: old,older.and very old
Quoted: 31 Post(s)
Front coaster brakes were used in the 30s---they were rare and bring a lot of $$$ on ebay.
Coasters can be adapted but they are a bit wider than most front hubs and the fork would need to be spread.
Shamino makes a type of hub brake---they call it a roller brake.Not imported to the USA.
sorry about your bike---but it's a good excuse to get a new one---sam
Phoenix Phreaks
Bikes: Custom Stretched Stingray Chopper with Glowing Green Fur
I saw a pixie with a hand actuated coaster brake on the rear wheel. He called it a gravity bike there was no apparent way to pedal it. I don't know how well it performed. I think it was on chopperbicycle . net . including a photo.
Later,
Allan Greenblazer
Later,
Allan Greenblazer
Also, lever operated drum brake.
put our Heads Together
Bikes: a mountain bike with a cargo box on the back and aero bars on the front. an old well-worn dahon folding bike
I really doubt you could get enough travel out of a lever to even start to apply the brake, let alone pull with enough force.
Videre non videri
Bikes: 1 road bike (simple, light), 1 TT bike (could be more aero, could be lighter), 1 all-weather commuter and winter bike, 1 Monark 828E ergometer indoor bike
They're available on a few models around here. Looks like they're actuated by a regular v-brake lever, but I haven't measured the amount of cable pull, so don't take my word for it.
Sister Annie
Bikes: Retro Hercules adult tricycle, 1953 Hercules ladies roadster, 1950s Wearwell fixed gear 'Club' pathracer, 1980s Malvern Star 'Super Star', 1980s Healing GTX-105 Arabesque, 1980's Morrison Concorde & etc & etc.......
So has anyone actually tried using a front coaster brake?
I should take down a spare Raleigh frame from the rafters and try putting one together.
OMNIPOTENS aeterne Deus, qui nos secundum imaginem Tuam plasmasti, et omnia bona, vera, pulchra, praesertim in divina persona Unigeniti Filii Tui Domini nostri Iesu Christi, quaerere iussisti, praesta quaesumus ut, per intercessionem Sancti Isidori, Episcopi et Doctoris, in peregrinationibus per interrete factis et manus oculosque ad quae Tibi sunt placita intendamus et omnes quos convenimus cum caritate ac patientia accipiamus. Per Christum Dominum nostrum. Amen.
Uber Goober
I'm riding a bike with coaster brake. It takes a lot of force to activate those well- comparable to the force you put into pedaling. I think doing it with a hand brake would be a bad idea.
