cleaning mildew off a bike trailer?
I did a search and didn't find a relevant thread, so I'm hoping someone can help me. I bought a 4+ year old Burley d'lite off craigslist last year. It had only been used a couple of times, and was in great condition. We took it on a test ride with my toddler, then stored it in our garage over the winter. When I pulled it out this spring, the back cargo area and the part of the straps that go behind the seat were slightly mildewed. The only help google gives me is this cleaning link, which suggests either bleach, lemon juice, or oxy-clean. I'm nervous about damaging the trailer even more, so I figured I'd ask for advice before trying any of these options. I'll be stopping in at my local bike shop later today, and will talk to them about it if they're not swamped, but I figured maybe other people here have dealt with this as well.
Quoted: 16 Post(s)
Undiluted white distilled vinegar works, just pour it in a a spray bottle and spray away and let it sit (preferably outside and in the sun) without rinsing. The smell will go away in a few hours and most, if not all the mold will be killed. Repeat as necessary. Between the vinegar and sunlight, the combo should kill any mold and mildew.
If you live nearby an automotive detailer or supply store, buy Microban Mildew & Mold Remover ($8.95 for 32 oz) or can order it here: https://www.topoftheline.com/32ozmicroban.html
This is what I generally use when I detail a car with mold/mildew problems and sometimes followed afterwards with an ozone generator treatment (few hours to overnight depending on how bad the problem and odor is). But an ozone treatment is for car/trucks in a closed environment and fairly dangerous, healthwise, if you don't know what you are doing. Airing out in direct sunlight is much safer and may take a few days.
tired
Bikes: Breezer Uptown 8, U frame
Also, get in touch with Burley. I'm sure they know what to do.
"Real wars of words are harder to win. They require thought, insight, precision, articulation, knowledge, and experience. They require the humility to admit when you are wrong. They recognize that the dialectic is not about making us look at you, but about us all looking together for the truth."
Bikes: trek,specialized,terry,
Sci Fi: Curious about using white vinegar & sunlight to kill off the mildew--I have a kid pulk sled that has some mildew on its Cordura nylon cover--I have used soap & water on it and rinsed it out & let it dry in the sun, but some of the black spots remained. Will white vinegar remove the black spots from the fabric? Cordura is waterproof, so the mildew is only on the surface of the fabric, not through it. Will the vinegar discolor the fabric like bleach would? Thanks!
tired
I just emailed DuPont. We'll see what they say.
Quoted: 16 Post(s)
Can use a good vinyl/fabric or convertible top protectant, like 303 Aerospace Protectant or Raggtopp, afterwards to protect the surfaces and add some water repellancy back into the fabric or vinyl, but you have to make sure you cleaned and dried everything or you will just end up sealing the bacteria in. A hair dryer on the low setting is one favorite way to dry things out or for larger areas...use an electric fan on high.
Thanks for the recommendations. I tried vinegar over the weekend, and it did a great job with the smell. It didn't do much for the spots, but I think maybe a few more attempts will help, or if not, I'll move on to the next recommendation.
