Using Road Frame on Track
Bikes: 05 Giant TCR2, 05 Specialized Rockhopper, 04 Specialized FSR
I have an opportunity to start riding track this fall and am wondering whether I can get started by using my Specialized Allez frame. I understand the dropouts are different, but my question is whether this is possible? I would plan on purchasing track wheels and crank. Any thoughts or your experiences are appreciated. Once I am able to find out whether this could be a long-term proposition, I will look into setting up using a real track frame. BTW, I have been looking at the Giant and Bianchi Pista Concept as good starter frames. Thoughts?
Thanks, Peter
Thanks, Peter
Some tracks won't allow it since the bb is low. But most do have rentals you can get started on. Email someone at the track to find out and see when they offer intro classes.
If you are going to convert a road bike don't worry about track cranks a shorter bb and road cranks will be cheaper and easier. Inless it's a really old allex with horizontal dropouts it's probably not worth the trouble.
If the banking of the track is really steep it may not be a good idea since your bottom bracket is lower and you will risk having pedal strike.
Also if your road frame has vertical dropouts it will make it difficult to get the chain tension correct which could result in dropped chains.
The fixed-gear/single-speed forum can give you more information on converting a road bike to a fixed-gear, just search for "conversions."
Thanks! Will check into a real frame. Bianchi Pista Concept looks very reasonable.
Peter
Peter
Bikes: Colnago
I'd say do worry about the crank length. My road cranks are 172.5 and 165 on the track 7.5 is a lot and on a steep track will pretty much ensure that you hit the deck. Track cranks are shorter for a reason
Contact the track you'll be riding on they may have bike you can hire out to see if you like the track.
Get yourself a cheap track bike - you won't regret it.
I agree to just rent at first, but if you want a track bike, bikesdirect.com has a windsor and a mercier for $300/350 which are track rideable right out of the box.
By the time you convert your bike, you will probably have spent over $300 and have a bike that is not really track worthy.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
I say, why it wont work? as long u r pedaling contantly u wont have a single problem. I have seen in london canada a few guys riding road frames in their track, and that track has a 55 degrees bank. I have seen people even running evnets in their road frames because they cant affor a real track frame.
So I dont see why u cant. Just be sure to kick some asses hehehe...
oldsprinter
No one seems to have mentioned that you can't simply buy track wheels and use them with a road frame. The widths are different. You would need to buy road-width track hubs (Phil Wood does them).
oldsprinter
The spacer idea is a good one. Although, on my old Dura-Ace hubs I ran out of thread for the bolt and could only widen them to about 125 or 126mm. It helped though.
But the OP said he's going to use a Specialized Allez - which, unless it's really old, has alumnium dropouts. I'd be worried about compressing them, and the stays, which would be aluminium, too.
The first bike I raced on the track was a Motobecane Grand Record converted to fixed gear. I borrowed some wheels, used a 3/16 fixed sproket in the back and the 52 tooth chainring on my Stronglight crank. It was crude but got me started in track racing. Used it for a full season at the Northbrook,IL velodrome.
During the mid 1970's Northbrook hosted the National Championships several years in a row. I broke into track racing at that time. The weeks leading up to the championships I raced in Junior races that had 60-70 riders. 1500 spectators was the norm. It was quite the scene. And one hell of a way to break into track cycling. You learn real quick how to handle a bike in tight quarters, especially during a "miss and out". We would fan out 10 abreast at the finish line trying to squeeze into impossibly tight gaps.
The only problem with a road bike under track racing conditions is the added torque on the bike from resisting on the pedals. My Grand Record made all kinds of funky poping and grinding noises. The chainring, soft french Stronglight acquired many gouges and nicks from the chain stress.
