Stolen Specialized Seat & Seatpost
I can't believe that someone would steal my seat and seatpost. My mountain bike is over 15 years old!
Here's my question --
What's my options when it comes to getting a new seat & seatpost? I went to Specialized.com and the only seatpost available was $155!!!
I bought my Specialized Rock Hopper mountain bike in 1992. I'd rather not buy a new bike!
Bikes: 2010 Tarmac SL, 2013 Fairdale Weekender, 2013 Fairdale Coaster, 1995 Specialized M2 Pro, 1972 Schwinn Heavy Duty, 2014 Surley Long Haul Trucker
Yep... just make sure you buy the right size. Chances are, it's either a 26.8 or a 27.2 seatpost.
You Know!? For Kids!
take the bike with you. go to lbs. ask them if they have a used/take off bin. go through it and find a used/take off post and seat.
Are you a registered member? Why not? Click here to register. It's free and only takes 27 seconds! Help out the forums, abide by our community guidelines.
Location: Beaufort, South Carolina, USA and surrounding islands.
Bikes: Cannondale R500, Motobecane Messenger
Quoted: 11 Post(s)
You can go to pretty much any LBS. Seatposts are almost universal, and bike parts in general can be interchanged between almost every bike brand. Bikes are not cars or appliances.
Not to bust your chops too much. Take your bike to a shop and they should measure the inner diameter of the seat tube with a caliper, then get you the correct size.
You might consider replacing the seat post clamp also. On my commuter I put a non quick release clamp on it when I got my Brooks. It cost like $4. I park outside locked to a bike rack and figured it would take all of 2 seconds to flip the quick release and remove the seat with post attached. This probably means it will take 10 seconds now, but at least the thief would need the right tool. I also see bikes that have bike chains threaded through the seat rails and around the top tube to keep the seat attached, run that through a little heat shrink tubing and it wouldn't scratch your bike.
Formerly Known as Newbie
You might consider replacing the seat post clamp also. On my commuter I put a non quick release clamp on it when I got my Brooks. [...] it will take 10 seconds now, but at least the thief would need the right tool. I also see bikes that have bike chains threaded through the seat rails and around the top tube to keep the seat attached, run that through a little heat shrink tubing and it wouldn't scratch your bike.
I also thought about running a cable or chain through the seat rails as an alternative to the glue method. Chain is too bulky and heavy IMO, and cable can be cut easily. I seem to remember seeing some kind of locking device, installed inside the frame, running cables to saddle rails inside the seat tube. I think such hidden cables might be better than visible ones. Maybe even attach a laminated note to cable in seat tube, saying "Smile... you're on Candid Camera" or something to that effect.
--J
To err is human. To moo is bovine.
Who is this General Failure anyway, and why is he reading my drive?
Become a Registered Member in Bike Forums
Community guidelines
Bikes: 1999 Kona Nunu, 2007 KHS Alite 3000
I always just take the saddle and post off, and bring it with me. A bike without a saddle is even further deterrent to a thief.
If I park my bike outside (which isn't very often) anything that isn't nailed down is removed or cabled.
