Why wouldn't one want 48 spokes?
Squirrel
Bikes: Borthwick Touring bike, 83 Schwinn Peloton, 94 Scott Cheyenne, ?? Bianchi Torino
They have a sale on Nashbar right now for Sun tandem/touring rims with 40 or 48 holes. $9.99.
Now, why wouldn't I want the 48 hole rims? I'm 210, so I probably don't need them, but why wouldn't one want as many spokes as they could get?
Squirrel
But I thought Clydes should consider tandem wheels because they're built stronger.
Here are my guesses (not that I agree with them):
If I need a super strong wheel, and I can easily find 48-hole front and rear hubs, I would get 10 of those rims for $10, and be set for the foreseeable future. Assuming, of course, that those Sun rims are good rims.
- Not exactly cool-looking
- Somewhat hard to find 48-hole hub that is not a tandem hub (i.e. wider than 135mm)
- Possibly higher labor cost to build wheels
- The more common 36-hole wheels can be strong enough with correct parts and build
Squirrel
OK, so let's say $10 more to get the wheel built, which you don't care about because you're saving $40 on the rim. You don't care if it's not cool looking, because you're sick of breaking spokes or tacoing wheels. And yes, supposedly normal wheels can be strong enough, but...well, it seems to be a major concern on this board.
So as far as sizing goes, which seems to be the issue, are tandem wheels a different width and won't fit on our normal bikes, then? Sheldon Brown has hubs for sale and they measure 100 mm in the front and 145 in the back... How do these sizes compare to, say, your average road bike?
I think* I have a 40 spoke wheel on the back of my Atlantis....
Bikes: Trek Checkmate, Lynskey Elysium, Trek FX 5 Sport
At 210, I think you would be good on 32 or 36 spoke count. I think 40 or 48 is overkill. I have 36 spoke on my hybrid and and 32 spoke on the road bike and don't have any issues. I am 295.
Back after a long absence
Bikes: 1974 Schwinn Speedster 3-speed, Raleigh Super Course
Since most loaded touring rigs I've seen run on 36 I can't imagine needing to go much above that unless you're really paranoid. I think the additional weight and hub cost would make the entire package prohibitive for me. The only way I would look at that much is if I was building my own wheels and acquired the parts (or at least some of them) for extra-super cheap.
Squirrel
I guess I just wanted to open a discussion on it and see if it was possible. There are enough wheel problems where someone may want to know that it might cost the same to get a much stronger wheel. Although maybe the deep V that everyone talks about is where the strength counts.
Out fishing with Annie on his lap, a cigar in one hand and a ginger ale in the other, watching the sunset.
Bikes: Techna Wheelchair and a Sun EZ 3 Recumbent Trike
Well, I wasn't thinking about myself, really. It's just that on Sheldon's site, you can get both hubs for less than $200, get both rims for $20, I don't know what spokes cost, and $50 each to build them. If there were Clydes around the 300-400 lb range and they're getting frustrated with wheels, it might actually be cheaper, if the Tandem wheels work with normal bikes.
or these in 48 spoke for just over $650 in 140mm, which can be fit into a 135mm stayset after cold setting.
Pricey, yes, but BOMBPROOF!
https://www.peterwhitecycles.com/tandemparts.asp
Most apps though should be good with 36-40 spoke and a strong modern rim like a deep V
. “He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you.”- Fredrick Nietzsche
"We can judge the heart of a man by his treatment of animals." - Immanuel Kant
Santana sells a Shimano tandem wheel with 16 spokes.
https://santanatandem.com/Parts/Shimano07.html
The main reason for fewer spokes is aerodynamic. I've never understood the strength issue, though, why a wheel with 16 spokes can be stronger than one with fewer.
Sister Annie
Bikes: Retro Hercules adult tricycle, 1953 Hercules ladies roadster, 1950s Wearwell fixed gear 'Club' pathracer, 1980s Malvern Star 'Super Star', 1980s Healing GTX-105 Arabesque, 1980's Morrison Concorde & etc & etc.......
I've used that type of wheel on a utility tricycle and they are absolutely indestructable.
OMNIPOTENS aeterne Deus, qui nos secundum imaginem Tuam plasmasti, et omnia bona, vera, pulchra, praesertim in divina persona Unigeniti Filii Tui Domini nostri Iesu Christi, quaerere iussisti, praesta quaesumus ut, per intercessionem Sancti Isidori, Episcopi et Doctoris, in peregrinationibus per interrete factis et manus oculosque ad quae Tibi sunt placita intendamus et omnes quos convenimus cum caritate ac patientia accipiamus. Per Christum Dominum nostrum. Amen.
I have been running a 48 spoker on the back of my touring bike for 10 years now. I have done fully self contained tours while being 350 lbs. Never had the wheel go out enough that it couldn't be ridden. I have taco'ed 2 36 spoke hand builts (told the builder was good before buying them) prior to buying them.
Remember with a touring bike even my weight at 350 is more than the bike is likley to handle with a "normal" touring load and rider. But with the gear and me it was hauling over 400 lbs.
