Questions about Campy Ergo lever rebuild
Old 09-06-07 | 11:26 AM
Ok brainy ones, I've done the research, found out why my Ergo levers don't shift right, discovered that I can probably repair it myself, and found instructions on how to do it. The problem is whether currently available campy spare parts will fit my older levers.
My shifters are '98 Campy Athena 9spd. In 98 Campy had 2 hood designs, and the Athena shifters kept the older pointy hoods. In 1999, everything went to the round hood style used today, so 1999 is a bit of a dividing line for parts availability & compatibility within campy's line.
I need to replace the Index Springs (G springs), and it looks like those parts are available and will fit fine. But I thought that, while I have the shifter's apart, I may as well replace some other pieces that are known to be wear-or-breakage prone. The problem is, I'm not sure if parts from 1999 or later, which are available from Airbomb or Branford bike, will fit in these 1998 shifters.
These parts are:
Index Spring carrier (campy part number EC-RE111); more recent versions of this part have are numbered 5-EC-RE111. But campy used EC-RE111 as the part number for many years on different 9 & 10 speed ergo shifters.
Right Coil Spring: 1998 Athena Part, EC-RE054; 1998 Chorus & Record Ergo, and all subsequent Ergo have EC-RE054 as the *left* Coil Spring, and EC-RE055 as the right coil.
EC-RE057: Bushing for the index spring carrier.
I suppose I could also upgrade this shifter to more modern 9 speed or even 10, but right now, I'd like to just get it working. The shifters are in practically pristine condition.
Will 1999 or newer parts (listed above), work in a 1998 pointy hood athena 9spd shifter, and if so, what modifications or special instructions do I need to know to make it work.
Thanks,
Rich
Richbiker is offline
Reply
Old 09-06-07 | 12:28 PM
Steev's Avatar
Go to the Campy website. They have parts manuals back to '94. Download the appropriate manual, order the right parts. As far as I looked into it, the parts are interchangeable. Certainly the G springs are.
Steev is offline
Reply
Old 09-06-07 | 04:19 PM
Bob Dopolina's Avatar
Mr. Dopolina
Titanium Club Membership
15 Anniversary
Bikes: KUUPAS, Simpson VR
You should be good to go. I'd still check the parts manual as there could be something I've missed here (I'm at home so can't double check myself). As far as the 5-EC-RE111, the "5" is just for bulk orders. On their price list they also have 50-etc for real bulk orders (for some parts). It is the same part.
One hint, easy on the grease and use the lightest grease you can find. I LIGHT coating and a bit more around the G-Springs is enough.
Bob Dopolina is offline
Reply
Old 09-06-07 | 06:54 PM
A little North of Hell
https://www.branfordbike.com/cgi-bin/...54748790#item4
Soil_Sampler is offline
Reply
Old 09-07-07 | 12:02 AM
Deanster04's Avatar
Bikes: Cinelli Supercoursa 69, Ritchey Breakaway Cross, Mondonico Diamond Extra 05, Coors Light Greg Lemond (built by Scapin) 88, Scapin MTB, Stumpjumper 83, Specialized Stumpjumper M4, Lemond Poprad 2001
branfordbike has a good cogent explaination on compatability. www.campyonly.com has good instructions on how to rebuild the levers, and if you need the parts you can probably contact Vecchios (google) and order the parts.
Deanster04 is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
