QUESTION regarding seatpost diameter
Bikes: nagasawa, fuji track pro
Quoted: 26 Post(s)
followup question:
so do i buy a stated "27.0mm" seat post for a 27.mm seat tube? intuition would tell me that it wouldn't work because the inner diameter of the tube and outer diamter of the post are the same?
can someone educate me?
-Nathan
for a 27mm seat post diameter tube is possible to use a 27.2mm tube. the measurement "appears" to be miniscule, but would this work?
on the flip side....will a 27.0mm post work in a 27.2mm tube and properly clamp or tighten?
thanks in advanced
-Nathan
thanks in advanced
Quoted: 26 Post(s)
jerk store
Bikes: '80s Chimo Garbage fixed 36/14, Centurion fixed 42/17
Yes, no to both questions. Seatposts come in 2mm increments from 25mm to 30whatever for a reason. Get the right one.
Quoted: 26 Post(s)
Quoted: 26 Post(s)
so do i buy a stated 27.0mm seat post for a 27.mm seat tube? intuition would tell me that it wouldn't work because the inner diameter of the tube and outer diamter of the post are the same?
-Natha
-Natha
Quoted: 26 Post(s)
antisocialite
when manufacturers list the "size" of the seatpost they're referring to the outer diameter of the tube. when they list the "size" of a seattube, they're referring to the inner diameter of the tube. they should be exactly the same.
Quoted: 26 Post(s)
well the questions i'm asking is if a Inner diameter and out dimeter are the same, then in theory* one pipe should NOT be able to fit in the other...
Quoted: 26 Post(s)
jack of one or two trades
Bikes: Old-ass gearie hardtail MTB, fix-converted Centurion LeMans commuter, SS hardtail monster MTB
Surly has a little essay on their site that covers this in detail. Read and be educated.
So just match the numbers.
