The Carryring POWER of Carry Me
Small wheels ARE better!
Ok ok, here is another rave about this micro-bike but guess what I discovered? Its ability to take on a good size luggage bag on its rear rack blew me away... No need for taxis!
My recent trip to KL, Malaysia.
OnF
OnF
There is more than enuf heel clearance. Quite well design I must say...
Becoz of the length of the CM, being a "standing" foldie bike, it wont fit into any regular size suitcase. But it travels great in its own bag and if need to be checked in, use the original packing box for great protection.
So far only my BF Tikit can fit into its own suitcase and tow it along... but it cost four times more than this Carry Me and is not as easy to handle around congested places.
Quoted: 321 Post(s)
Liked 7 Times
Looks awesome! Certainly makes me want one for trips.
What do you think of the chain - it is a special part, isn't it? Is it easy and not too expensive to get hold of?
Chain is not yr regular bike chain but more like a chain saw size one. The distributor have spares so no worries in this part of the woods.
Someone wrote to tell me its a 58T chain ring and 13T sprocket, which would be about a 9.25" diameter chainring (normal 1/2" pitch chain.) About a 6" chainring, so the chain pitch must be around 1/3.
Does that make sense?
I believe the crank length is 160mm. That might be enough difference (10-15mm shorter) from "regular" cranks to have good heel clearance with oversize luggage (unless you have clown-size feet). You might not be able to put 170mm or longer cranks on it anyway because then your pedals might scrape the ground.
Yes, gd point indeed. Thks Skidurts. One drawback of the CM is that the pedals get scraped easily during corners if you are pedalling. So must be mindful of its lower than usual clearance...
That said, the Carry Me is one cheap and great value urban commuter. Perfect for twinning with buses/trains, more than capable for 3-5km rides. The ability to carry stuff of course, is its forte!
P.S. One of the A-bike's double drive trains also uses a #25 chain and sprocket (the other uses standard 1/2" pitch).
Señor Mambo
Bikes: TST roadie, Cannondale CAAD 3, Surly Karate Stokemonkey Leap, Tern Cargo Node, Helix Alfine; 36er and 29er Triton Unicycles; a couple Bike Fridays; one Brompton; RadPower Radburro
Quoted: 54 Post(s)
Liked 28 Times
Is that the standard carrying rack on the back? The rack on the web site looks different; it also has wheels.
How's the bike handling with that kind of load?
It's the same rack. The rack wheels are also hinges that allow the rack to unfold. If you can imagine, it's like there are two racks attached to the wheels: One of the racks is also attached to the frame, while the other is free to swing around the wheel.
