Smallest practical wheel size?
I've got a cheap A-Bike knock-off with 6" wheels. It's ride-able on smooth surfaces, but you feel every crack in the pavement. Gravel roads or other loose pavement are out of the question.
On the other hand, my Strida with 16" wheels is fine on gravel and every other road surface I've come across.
Between those ranges, what is the smallest PRACTICAL wheel size for typical city use (mostly paved, but with the occasional rough patch)? Is 6" even usable with perhaps a wider tire or some kind of suspension?
Looking for replies from people who actually own and ride on smaller wheels.
In general I think that wheel size is much much less important than people think it is. People think that since drastic changes in wheel size result in drastic changes in appearance, it should also indicate drastic changes in rideability. I believe this is a misconception similar to the misconception that small wheels require you to pedal faster. People that understand gearing know that small wheels do not necessarily require you to pedal faster, just that you need to compensate the gearing. Likewise, I believe that small wheels do not drastically affect ride quality as long as they are compensated for elsewhere.
In my opinion the only disadvantage of small diameter wheels that can't be compensated for by other means is the tendency of the wheel to get stuck in cracks. If the diameter is smaller than the cracks then this becomes a problem of safety. If the diameter is bigger then the crack then this becomes a problem of efficiency. Everything else can be compensated with suspension, longer wheel base, etc. For example, look at cars. Despite wheels of around 20 inches in diameter, they seem to manage fine at extremely high speeds on extremely poor roads. They compensate for the small diameter with both a longer and wider wheel base and a sophisticated suspension system.
Thus, neglecting efficiency, the smallest practical wheel size is slightly larger than the biggest crack you plan to encounter. I think six inches would be fine in most situations if you had wide tires, good suspension, and a long wheel base. Of course, these things would make the bike larger and heavier, somewhat negating the advantage of the small wheels.
... smallest practical wheel size is slightly larger than the biggest crack you plan to encounter.
Additionally, the biggest BUMP you might encounter is a factor as well - if you can't avoid it or unweight the front wheel over something. Last night I was turning tight figure-eights in my driveway to show off the A-Bike to some friends, and suddenly the front wheel just seized as solidly as if I had hit the brake.
I kid you not: The A-Bike choked on a small pine cone.
Not me, I'm with you on this one.
Good point, "smallest practical" depends on what you're riding on. 90% of my riding is smooth pavement, yet I live on a gravel road. So however small I go, I need the widest practical tyre. What kind of rubber comes on the CarryMe?
The width of the Carryme's tires are 1.5". Not very wide, but I believe the wheelbase is much longer than the A-bike.
In short: The Strida is ride-able on gravel and the A-Bike isn't.
Bikes: GT3 trike,Viper chopper, electric assist Viper chopper,Electric moped(Vespa style)
Another factor to consider is that below 16" the range of tyres is not that great.
It's hard enough getting decent perfomance 16" tyres in my City.
Small wheels ARE better!
I tour with 20" wheels - find that its the most optimum size for performance and folding. But the little 8" wheels on the Carry Me surprised me. Would you believe it can be ridden on a Malaysian oil plantation unsealed road? Its possible and was attempted successfully recently by one of my crazy friends...
Here's proof -
Guess its the rider, not the bike at the end of the day!
Here's proof -
Smiling and Waving
Bikes: -
I'm sorry but anything with smaller tires than 20" feels like a child's toy to me.Like if I crank too hard something will snap or bend.Not so good if you have a longer commute.
Smiling and Waving
Bikes: -
The Moulton is definately strong enough.It's built like a real bike.Same as the Twenty,good solid bike.But still not so great on a longer tour.Those 16" wheels just aren't as smooth as the 20".And the prices for these bikes are starting to get crazy.
I've got 16" wheels on my giatex. The advantage I've found for the smaller wheels are that it seems a bit easier to get up steep hills. Maybe that's just my imagination, though. I've also found that acceleration is faster (which is bad on a bike where most of the weight is in the back. I've almost fallen over backwards a few times). I think if my bike had better gearing and some form of suspension, the wheels would be fine.
Eschew Obfuscation
Bikes: 2005 Fuji Professional, 2002 Lemond Zurich, Folders - Strida, Merc, Dahon, Downtube, Recumbent folder
I'd grant you that the ride is twitchier, but that doesn't have anything to do with strength or durability.
Bicycling Gnome
A well engineered 16" wheeled bike can be as tough and durable as any other. You'd have to think carefully about going fast off road, but you would on a 700c racing bike too. I think we should be careful about making wrong assumptions about children's toys and small wheeled bikes. Maybe they don't appeal to everyone's idea of what a bike should be. That's fine, but it doesn't mean they aren't as tough as old boots. I met an old guy with an eight year old Brompton the other day out in the middle of nowhere. He'd got on a bus with it in the morning, travelled twenty five miles, and was riding it home. He said he did this about three times a week and that he had put over 15000 miles on the bike. He was at least 65 years old. I think the bike will outlast him easily.
In high school I used to ride a Honda scooter with 90/90-10 size wheels (16") and it was no problem. Even took it up to 80 mph a few times and the ride was pretty stable. Though the wheels were much wider than bicycle wheels.
I think that 16" is the smallest you want to go. Even with a lot of gears, 8" wheels won't get you very fast.
Quoted: 16 Post(s)
Liked 24 Times
Based on my experience with 16" Schwalbe Big Apples I'm inclined to think you could make something fairly useful using their two smaller sizes - 50-203 (12 x 2.00) & 50-254 (14 x 2.00) The 12" is rated for a 70 Kg load.
I'm pretty fussy about tires, and don't want to spend my ride paying close attention to road surfaces, so thats as small as I'd go. For tires that small, suspension would be a big plus, especially if it were part of the folding system.
Bikes: Mobiky, PBW, Jim Redcay, old Chicago Schwinns
I think the 203mm rim size may be the smallest practical size for building up a traditional spoked wheel, which allows the use of available hub gears and hub dynamo. Has anyone seen a smaller wire spoked wheel?
