Best value for a taillight
What's a good taillight ( READ: brightest, most visible ) without spending a lot of money. Relative newbie here who's concerned about not being seen.
The Fenix Shillboy
Bikes: Raleigh F500 mountain bike and an exceptionally old (mid-60's) Schwinn Collegiate 5-speed.
Planet Bike Super Flash. Most bang for the buck. Always on sale somewhere, should be able to get it for $20 or less, shipped.
Check out this review on the CandlePower Forums (and search "Planet Bike Super Flash" on this forum for more info and accolades):
Two Rear LED Bike Lights - A Joint CPF Review
The Fenix Shillboy
You're welcome!
I recently went through your same exercise to find a good tail light. I wanted the DiNotte tail light (approx $150 US). I bought the Planet Bike Super Flash (less than $20 on sale). Someday (perhaps), the DiNotte. For now, the Super Flash.
I also have the Cateye TL-LD1000 (another nice tail light, probably not quite as effective as the Super Flash in a few ways and more more expensive than the Super Flash). But you will have read about the Cateye in the review on CandlePower Forums that I linked.
I am not saying the Blackburn is better. But the group I ride with is very safety conscious and several of them bought Mars 3.0's after they saw mine.
The Fenix Shillboy
My question is, "How do the Super Flash and Mars 3.0 compare in terms of side visibility?" I've been curious about the side panel (amber?) on the Mars 3.0 and whether it makes a better side visibility light than the Super Flash.
I am currently running both a Super Flash and the Cateye TL-LD1000 to help more with my side visibility (I'm not overly concerned with extra weight on the bike, but want good visibility).
This is how my rear lights are currently set up. Shot it diffused daylight indoors, this doesn't really show the overall night look very well, but does show how they're set up and a bit of the side visibility. I run the Super Flash in blinking mode and the TL-LD1000 solid.
I couldn't find that Super flash anywhere near me (in Dallas). So went with the Cat Eye TL-LD1100 from REI. Cost more but so far it makes me feel alot better riding.
I stand corrected. After doing some testing last night I've found that the Mars 3.0 is much more visible than the SuperFlash from the side due to the amber flasher, and much more visible during low light conditions such as dusk due to it's larger bank of lights.
Where the SuperFlash excels is in total darkness where the small but powerful light is noticeable due to not only it's power, but also it's odd flashing pattern.
In conclusion I'd say for riding when it's not pitch black out the Mars 3.0 is more visible than the SuperFlash. During pitch dark the SuperFlash is a bit more noticeable due to it's odd flashing pattern.
NOTE: I've noticed previously that during daytime or in low light conditions the Cateye TL-1000 is more visible than the SuperFlash, yet during pitch dark the SuperFlash is much more noticeable than the TL-1000.
The Fenix Shillboy
Your findings might also provide some justification for someone to run both the Mars 3.0 and the Super Flash (kind of like I'm doing with the Super Flash and the TL-LD1000).
Out of curiosity, can you give an approximate size/weight comparison of the two? Is the Mars 3.0 much larger than the Super Flash?
And just to add (not personal experience, but from reviews read), those who complain about the Mars 3.0 say the batteries are a pain in the butt to change (tiny and inconvenient screws?) and the attachment clip (?) leaves a lot to be desired (several people complained about losing theirs on the road). Again, that's just from reviews read.
They both had fresh batteries, and they are almost the same size with the Mars 3.0 being slightly bigger and heavier but not by much.
As for the batteries in the Mars 3.0 that is a problem. It has a bone headed design which indeed uses a tiny screw to fasten the battery compartment. It's an absolutely horrible design.
The mount seems quite good and is similar to the SuperFlash as a tab slides into the bracket.
The Fenix Shillboy
Good info, Ziemas. Glad you posted your comparisons and comments.
On the Super Flash mount, I seem to recall a couple of threads I searched though where others had said they had lost their Super Flashes on the road, too (just as those who had the same comments about the Mars 3.0). But in looking at my Super Flash, it seems like a pretty solid snap-in mount. Doesn't really seem to me it would come loose easily if snapped properly into place, so I dunno what to make of the road loses...
Bikes: MTB Peugoet Canyon (forgot the model), Nikishi? roadbike, MTB custom build,
Thanks.
Senior_Member2
Bikes: Beater + Nishiki Bigfoot X-29
You could build this for sub 20$ cause it cost me like 10eu excluding the tin and cells.
The Fenix Shillboy
TL-LD1100
I also recommend the PB super flash. In multiples - one on helmet, 2 or 3 on bike. I got mine for 14-16 bucks on sale.
Also, lithium AAA batteries, although expensive, ensure max light output with long life and minimum hassle.
The Fenix Shillboy
btw.. It's BRIGHT.. Wife was riding behind me the first time I used it. She said WOW that's bright. And it was 95 and sunny at the time.
Senior_Member2
My wintergreen tin was really nasty (forgot some candy in there). More info on the light:
Its not water proof (yet).
1w Red led (luxeon) (5eu)
2x 1.2v AA cells for 2.4v direct drive.
i used arctic silver5 to create thermal contact with the tin (which i sanded with a scotch-brite pad)
And some generic luxeon lens for around 2eu.
I used a dipole switch cause thats what i had. and the batt cradle was like 30cents. probably cheaper in the states.
Also for all you superflash users. how is the led cooled?
I ride in pitch black in the winter with a group. I have both Mars for redundancy and better visibility when it is pitch dark. I got a view of our group from behind once. It was a sight to see. Everyone had their light in the brightest flashing mode and many have two tailights. You cannot believe how much visibility a group like that creates. It looks like a fire scene with all the firetruck lights and police car lights flashing. Motorists probably think they are approaching a bad accident scene!
I have 2 Mars 2.0's and the plastic tab connecting the seat post bracket to the light has broken on both, in less than a year. I use the clip-on bracket and secure it to my saddle bag with twist ties.
I have not used the 3.0 long enough yet to comment on it's durability. But I like the seat post bracket better since the clip-on bracket slides in to it instead of using a small plastic tab that can fail. I have seen comments that battery life is very short and others say that it is easy on batteries. Again I have not used it enough to know. I just put brand new batteries in mine so I will have first hand experience this winter.
I was torn between the Superflash and Mars 3.0 but chose the Mars mainly because of availability from my LBS.
Healthy and active
Bikes: mid-60's Dunelt 10-speed, Specialized Allez Sport Tripple, Trek 7.2 FX
I have been using a Bell LED flashing taillight from Wal-Mart both in city traffic and on rural roads. A friend saw me riding and even came up behind me in his vehicle one night without knowing who the cyclist was. He said I was visible from half of a mile away. If find cars generally go into the left lane to give me plenty of room. The Bell unit costs less than $9 and has six or seven modes with different light patterns. It runs a long, long time on 2 AAA batteries.
not a role model
My vote is for the Superflash - no contest.
