krazy glue
Halocon
Bikes: Orbea Onix (105)
krazy glue
is it safe to use krazy glue on my carbon frame? the "onix" logo on my orbea fell off and i'd like to stick it back on. thanks for the help guys!
Bikes: Kona Zing, Univega Rover 303, Schwinn Traveler, Mercier Kilo TT
The frame may spontaneously combust, but they usually just explode.
Wear goggles.
Wear goggles.
W.W.DZ.D?
Krazy glue is pretty strong stuff, so it might eat away a bit of the clear coat. You might want to try something a bit less harsh.
It will not harm either the frame or logo - but it is not a very good choice either. Krazy glue is very poor at gap filling, i.e. to work well the two objects need to fit together perfectlylike cracked china etc. If you do use it make sure it is the gel type, this will fill small gaps and stay in place without running onto places you do not want it to be. A better choice is 5 min epoxy, it comes in a syringe type dispenser. Mix up a small batch on a piece of cardboard and with a tooth pic or wood match apply a few dabs and hold the logo in place with masking tape until the epoxy cures. With either adhesive it is best to prepair the surfaces to be joined by LIGHTLY sanding each with very fine sand paper, 400 grit or finer, or with Scotch brite pad. Just sand enough to take a shiny surface and make it dull, no more. Be sure to not sand anything the logo will not cover as it will ruin the finish.
Bikes: 2007 Orbea Onix, 2007 Windsor The Hour, 2008 Kona Jake
I had this happen to me last week. I sent an email to tech@orbea-usa.com on 9/11. I haven't heard back yet, but will post what they send me when they reply.
Gorntastic!
Certified Train Wreck
Bikes: '07 Orbea Orca "06 Bianchi Castro Valley
Use some Zap glue. It is flexible, and won't hurt your frame.
www.websterhenry.com
Bikes: KHS steel SS
Road Runner
Bikes: Specialized Allez Triple
Gorilla glue, possibly? I used the stuff at work and would say its stronger than crazy glue and a bit less harsh (at least if you get it on hands/paint, etc), but it does expand a lot, so a LITTLE dab will do ya.
Hello,
Somehow my reply was going to a email address @ craig’s list.
Please email me you address and I will ship you new ones.
To: tech@orbea-usa.com; kevin
Subject: RE: Onix badge fell off
Date: Tue, 18 Sep 2007 06:21:43 -0500
Hi,
I'm re-sending this in case it somehow got lost in processing.
Hi,
Subject: Onix badge fell off
Date: Tue, 11 Sep 2007 10:42:09 -0500
Hi,
My brand new 2007 Orbea Onix badge fell off. I'm talking about the badge by the seatpost that says "Onix". Is there a recommended product I should use to glue this back on, or can you send me a new one to install?
Thanks in advance for your help.
Kevin
Hi,
Kevin
Young and unconcerned
Bikes: Yeah, I got a few.
Ha ha - yeah, they're quick to get their branding back on!
Still curious why it wasn't under the clearcoat.
Back in the day, when I worked at a camping gear store, some fancy kevlar quick-pull lace things on my Salomon trail shoes broke - I asked for new ones, which they duly sent, along with fist-fulls of Salomon stickers, which being the crazy 19-year-old I was, subsequently ended up all over the place. Very wise of them. (this was, of course, before they were bought by Adidas and became crap)
