Heavier rider in front or back?
Would it be easier to learn to ride tandem with the heavier person as captain or as stoker? Both riders are almost the same height but one is quite a bit heavier than the other. Thanks!
Bikes: Co-Motion Mocha, Trek T100, Schwinn Fastback Comp, Specialized Stumpjumper
All things being equal, you'd want the heavier rider as captain, but cycling skills can easily compensate as long as the stoker does not throw his/her weight around (which would be a problem in any case even with a light stoker).
So the answer really is what works for you, if you have the luxury to test it. Many of us don't have the option of switching with the stoker because the shorter rider often is too small for the captain's bike size.
Bikes: Trek T200 plus enough others to fill a large shed
Most people find that heavier at the front works better since it's like riding a bike with panniers (easy) versus trying to ride with a fridge sitting on the back of the bike (Not easy). Try it and you will soon see for yourself. (I mean swapping places, not riding with a fridge)
Only exception to the rule is where weight differences are not huge and lighter rider has better bike skills.
Quoted: 77 Post(s)
Liked 19 Times
Whoever of your team is more comfortable/able to pilot the tandem takes the front.
Have piloted a tandem with a stoker twice my weight . . . no probs, 'til stoker tried steering from the back!
Agree that it must be nice that either one of you will fit front/rear of your twicer.
We gave the tandem a quick try and it seemed to work better with the heavier rider in front. Will have to practice more to see which way works best.
Sir Fallalot
Quoted: 9 Post(s)
Liked 13 Times
Heavier in front. Actually, stronger and heavier in front. If the stronger rider is ligher, I'd still put the heavier in front, unless the lighter is much stronger and not much lighter.
All clear?
All clear?
