removing stock pedals
Bikes: '11 Allez Comp, '09 Pinarello Pista
ok, i just got my clipless pedals today and I'm trying to install them. Problem number 1: how do i get the crank to stop spining so i can take the stock pedals off?
thanks
-Ross
thanks
-Ross
It's all leverage, get the wrench so your almost squeezing the crank arm and wrench together, remeber the opposite threads, i believe the wrench always goes towards the rear of the bike.
alright, < 1 hour later with some assistance from a wall and my little sister "we have gone clipless!" The first time i saw someone getting into their clipless for the first time, i laughed and thought that it had to be easy... I now know it takes Talent to not fall over!!!
Still this begs my first question, how would you go about locking the crank arms, is there some technique, tool or magical chant?
DEADBEEF
From: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
1999 K2 OzM
"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
1999 K2 OzM
2001 Aegis Aro Svelte"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
Park Tool site recommends torquing the pedals down to 360 inch pounds. Why so much? Like automobile spark plugs, I only give them maybe an extra quarter to a half turn with the pedal wrench after tightening by hand. This makes removing the pedals so much easier in the future. Never had loose pedal problems....ever! The direction in which pedals are threaded and with the crank motion, it's impossible for them to work themselves loose. That's how I look at it...
To remove pedals, rotate the crank forward at about the 10:00 position. Place the spanner (us wrench) on the pedal, but facing backwards, with the handle pointing slightly upwards. Apply brakes. Stand on wrench. The wrench will turn a little, till your foot stands on the crank arm. You can then spin off the pedal by hand.
It's kind of hard to describe how to remove pedals. A couple of the folks here have done a pretty good job. The key for me is aligning the wrench essentially right beside the crankarm and pushing down, or along the inside of the crankarm and having the wrench move towards the bottom bracket. It's an angle thing. You really don't have to do anything to hold the crankset that way.
360 in lbs. really isn't all that much, 22-23 foot lbs. Really that's just snug and a small grunt. Most folks put too much torque on their pedals, or attempt to cross thread them. That's why they can be so tough to remove.
I say stand because if you grab the wrench with your hands and push down, the pedal will suddenly loosen, and you will catch your fingers between the wrench handle and the crank. A gentle nudge using your weight on the wrench is finger-safe. I wouldnt use my feet to tighten the pedal.
