will this work?
Old 08-13-03 | 09:21 PM
ShadowRider's Avatar
20 Anniversary
will this work?
in my quest for a custom bike i've decided to take a 24 inch wheel and put it on my 26 inch bike (the back) so i'm very relaxed while riding
will it work? the gears are the same (18 speed) all i'd worried about is brakes, but i can just put front brakes on it
AWESOME WHEELIE!!
ShadowRider is offline
Reply
Old 08-13-03 | 09:59 PM
sch
20 Anniversary
If you are riding flat trails and relatively low speeds, this may be ok. Bike brakes are pretty marginal as is, it is easy to lock a wheel up and skid, and a
skidding front wheel means you have only a few seconds to regain control and prevent a crash. Since the wheel is smaller, and you are tilted backward a bit
you are less likely to take a header, but I suspect you could still manage to do a header in an emergent situation. One brake means that you can scrub speed off much more slowly, so going above 15-20mph and needing a sudden stop will give you sense of the meaning of Einsteins' concept of time dilation,
if you avoid a header. Steve
sch is offline
Reply
Old 08-13-03 | 10:14 PM
20 Anniversary
the brakes arent good on this bike (the fastest i've been is 50 mph and it stopped relatively fast)
it only has back brakes but i can flip them around
ya see, it used to have front and back, but only the front worked right, then after sitting outside a winter the front brake cable was junk and not knowing how to fix or replace cables i just took the front brakes off and went brakeless for awhile until i figured out why the back brakes didn't work (the pads were made too skinny) so i put some OLD used ones on and that's where i've been with it for 6 months now
Reply
Old 08-14-03 | 02:39 AM
Aggressor's Avatar
Resident Music Junkie
20 Anniversary
Bikes: 2000 Avanti Aggressor
Check out BigHit-Maniac's bike. You'll see what it looks like
Aggressor is offline
Reply
Old 08-14-03 | 12:02 PM
20 Anniversary
where can i find that bike?
Reply
Old 08-16-03 | 08:45 AM
20 Anniversary
does the brake reach? Or do you have discs? you can see bighit's bike in the post your mountain bike thread
Phatman is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
