Brake cables under tape
Quoted: 38 Post(s)
Liked 11 Times
Can the brake cables be run under the handlebar tape with old style brake levers (1970-80ish) or does it take a newer style lever to do that?
Booger1
Booger1
The Red Lantern
There is also the trick of looping them back around to the bar and running the housing like a modern aero the rest of the way, under the tape. You end up with a short exposed loop but it is not bad looking.
Are you a registered member? Why not? click here to register. Its free, and only takes 27 seconds!
Help out the forums, abide by our community guidelines.
I am in the woods and I have gone crazy.
Quoted: 38 Post(s)
Liked 11 Times
I tried the loop thing but it seems I would have to loop to the outside of the bar then back under and that's where I do all my riding.Thanks Everyone...Going to the LBS tommorow,I'll check out some levers.
Bikes: Giant TCR Comps, Cdale R5000, Klein Q-Pro, Litespeed Siena, Piasano 105, Redline Conquest Pro, Voodoo Bizango, Fuji Aloha
What you have are called non-aero brake levers, you need aero brake levers to have the cables routed under the tape. Did that recently to a 1983 Trek 410. New Tektro levers at Nashbar (as well as other places) were about 20 bucks, pretty simple swap.
Bikes: Trek 5500 OCLV, Trek Fuel EX 9
Bikes: Surly CC, Raleigh Team Pro, Specialized Rockhopper with an xtracycle
I just got some tektro off of ebay all for under $25 bucks... came with new cables as well. If you are going to salvage your older calipers and cables, i would recommend that you grease the cables before you slide them into the housing.
Quoted: 38 Post(s)
Liked 11 Times
Just got back from a ride to the beach and hit up the shops along the way.One place had a NOS set of shimano levers/with covers,let me have them for $10,lucky day I guess.
Thanks again everybody.
