Break+Powder Coated Rims = Terrible Noise
Hopeful Monster
Bikes: cannondale synapse, custom frakenstein fg
I recently added a front break to my fixie and the noise it makes has gone from bad to terrible within a matter of days. I have a Velocity deep v Wheelset. This particular wheelset is powder coated, and I have a strong feeling that this is the reason my breaking sounds like a hell scream. Does anybody have a remedy for this or should I get some earplugs?
loves his IRO.
Bikes: IRO Angus, all sorts of upgrades.
Then just buy a rim, and relace it with the **** you've got on it now.
Hopeful Monster
I'm looking for a solution that doesn't involve buying another rim. Maybe some kind of lubricant/goo/herb?
Bikes: SE Quadrangle, '82 Venus NJS, '03 Bianchi Pista, '86 P'sonic Mt Cat, Fat City Yo Eddy '91 + '93, B'cuda A2E, '86 Trek Elance 400, '88 Centurion D.Scott Expert, '88 Fisher Mt Tam (and no longer with me: SE OM Flyer, Umezawa/B-stone/Samson NJS)
Maybe try to fix the break? Splint?
It has to do with the positioning of the brake shoe.
Make sure the part of the brake shoe that touches the rim first is the part closest to the front. And that the part of the brake shoe that touches the rim last is towards the back.
Hopeful Monster
barba, thats what I am thinking. Should I clean the black residue off?
i'm losing my bread.
dirt pinned between the brake pad and braking surface cause brake noise. keep your braking surface clean (the fact that you're rubbing away the powdercoat isn't helping that situation) and clean it with simple green. you might want to sand your brake pads just a little as well, but that's just an extra precaution.
raodmaster shaman
file the pads down a bit, toe them in, rub the braking surface with sandpaper to make sure its clean and smooth.
any goo or lubricant is a big no-no.
if you really want to go for it, mask and knife and edge into the PC, then use a sanding block to take off the coating and essentially machine the rim yourself. Or find a machine shop with a big lathe...
Bikes: 2012 redline conquest pro / 2008 yeti 575 / motobecan fantom cross uno
just wait for it to break itself in.
LF for the accentdeprived
