Spoke recommendation for a Nexus hub
Old 10-10-07 | 11:19 AM
I haven't a clue about spokes. Please enlighten me.
mosquito is offline
Old 10-10-07 | 11:56 AM
15 Anniversary
DT Swiss 14/15/14 2/1.8/2 double-butted spokes with brass nipples will be strong and reliable. If you need to save some money, consider the straight gauge spokes. Buy an extra spoke or two in each length you need so you have a backup in case one breaks.
niknak is offline
Old 10-10-07 | 03:30 PM
20 Anniversary
Bikes: Priority Continuum Onyx; Hunter CX
I think this is perfect advice. I used the 14/15/14 for mine and have carried fairly heavy loads (~45 pounds) on a rear rack plus me (~175 pounds) and haven't had any trouble. I'd definitely use double-butted spokes, but as mentioned, you could save a little money with straight-gauge spokes. Notably, my LBS has a much better length selection in straight gauge (oddly, the owner, whom I generally respect, insists that straight gauge spokes are inherently stronger, but many reliable sources say just the opposite).
-D
Derailed is offline
Old 10-10-07 | 03:42 PM
kipibenkipod's Avatar
Got an old Peugeot
Bikes: I had a Trek 1200
Read peter white page of custom wheels. It will give you some insight on things. He gives a lifetime warranty, so you want to use what he use in order to have strong wheel.
https://www.peterwhitecycles.com/wheels.asp
kipibenkipod is offline
Old 10-11-07 | 07:49 AM
I live in NY, and a LBS guy siad that straight gauge spokes are better for the city becuase they're stronger. I guess he didn't consider carrying heavy load.
From what I've read, db all the way.
mosquito is offline
Old 10-11-07 | 11:35 AM
Part of the issue of stronger comes down to what breaks spokes in the first place. Do spokes break in normal touring usage because they weren't butted or straight? I don't think so, except at the extreme margin. Spokes break because of three main reasons:
1) improper instalation, this means a slight bias against any machine made wheels that require certain less than totaly optimum materials and techniques in building, or it means bad hand building. As to the latter there are presently at least 3 specilist books on this subject. People still argue about Jobst's book, and the other two recent ones have been warmly received by insider reviewers with quotes that imply something precious has been revealed. Apparently it isn't all as obvious as it might be. Further evidence is the lords of spokecraft, people like Jalon Hawk, Peter White, and quite a few others, who have a reputation for doing it right which is only possible if someone is doing it wrong.
2) Bad materials. A lot of wheels are not being built out of DT Swiss anything. Is your Chinese butted spoke machine made wheel going to outperform the super wheel built with DT straight spokes, DT hubs etc...
3) Bad fit in components. Good materials poor combos. It's not just a mater of what you use and how you use it, but there are spokes that will not be properly supported when used in particular hubs. There has been some complaint about certain spokes being redesigned for insertion in the machine sequence that no longer hold up to custom wheel standards.
Do properly built wheels break? I don't think they do. Why do my wheels never break at my 220, while someone weighing 100 pounds has lots of trouble. Why does Jobst recoment not replacing spokes when rebuilding wheels due to rim failure? The focus needs to be on what maters, and part of what maters is that straight spokes are more rugged outside of the tensile plane in which spokes snap when they are riden on. Neither butted nor straight spokes should break in use, so you need to look at other sources of breakage like panier hooks in the wheel.
NoReg is offline
Old 10-24-07 | 12:46 AM
Got an old Peugeot
Can you list the books?
Thanks
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
