Can I Upgrade?
Can I Upgrade?
I've got a new 27' wheel coming for my 1980 Motobecane Jubile Sport. I'm planning on switching the DT shifters to bar-ends soon. My question is... Can I upgrade the rear from a 6spd to 7spd? And how hard would it be if possible? Or is it worth having my LBS install the cassette?
Quoted: 1572 Post(s)
Liked 643 Times
The short answer is you can definitely upgrade to a 7-speed.
The more adequate answer can get pretty long. Potential issues include dropout spacing and repeated bent rear axles. At best, neither will crop up as a problem. Also at best, you won't be gaining much either.
The Improbable Bulk
Bikes: Many
Quoted: 5 Post(s)
Liked 7 Times
Also, you are probably confusing the term cassette with freewheel.
Freewheels are screw-on and are available in (typically) 5-7 speed and cassettes are locked on either with a lock ring, or the last cog acting as a lock ring, and are available with usually 7-10 speeds (with some 6 speeds)
More info here:
https://sheldonbrown.com/free-k7.html
I am having my LBS build a 27" wheel with a freehub so I can upgrade my bike to use up to 9 cogs... I would change to 700c, but my bike uses Cantilever brakes without the adjustment I would need to get to the 700c rims.
More info here:
Slow Ride Cyclists of NEPA
People do not seem to realize that their opinion of the world is also a confession of character.
- Ralph Waldo Emerson
Quoted: 2026 Post(s)
Liked 1,096 Times
Shimano's 7-speed freewheels are index compatible so they have the improved tooth shape. Nashbar's housebrand freewheels (made by Sun Race) are also index compatible.
