Swapping Cranks
Swapping Cranks
Old 10-20-07 | 04:49 PM
Swapping Cranks
Can you swap out just the cranks for shorter ones? Or does the whole crankset including the chainrings have to be replaced? I have a Bontrager triple.
Sportsman9 is offline
Reply
Old 10-20-07 | 05:53 PM
MudPie's Avatar
20 Anniversary
You could swap out the arms and reuse the chainrings if:
1) the chainrings are compatible with the new arms (bolt pattern, mounting configuration)
2) the arms are compatible with the current bottom bracket. For example, you can only use ISIS splined bottom brackets with ISIS crank arms.
As an example, this page shows a bunch of available crankarms, some with chainrings, some without.
https://www.jensonusa.com/store/sub/1...ts.aspx?s=1257
MudPie is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
