Regina Extra freewheel maintenance?
shedding fat
The freewheel in my classic bike, a '84 Guerciotti, has been making a creepy noise as if it has a loose bearing ball and some sand in it grinding as it turns. I thought at first it was the hub needing repacking, but after getting it repacked, cleansed, and even putting new ball bearings just for the heck of it, I am sure it is the freewheel. Is there another bearing inside the freewheel that can be serviced as well?? Or do I just need to try to replace it with another freewheel altogether? It is a 6 speed (13-21) Regina Extra by the way. The guy at the LBS did not seem to know what to do with it other than tell me he thought it was the freewheel too. Just in case, I ordered another already froma guy on ebay, but I would like to salvage this one as well if at all possible.
Arguing with ignorant people is an exercise in futility. They will bring you down to their level and once there they will beat you with their overwhelming experience.
You can try and take the freewheel off of the hub, hold the center and spin the sprockets while dripping light oil in the crack to relube the bearings.
Or.....
https://sheldonbrown.com/freewheels.html
scroll down for freewheel rebuilding
Or.....
Bikes: Surly Cross-Check
here are some extra ebay auction links for an regina 6 speed
https://cgi.ebay.com/NOS-Regina-Extra...QQcmdZViewItem
Quoted: 140 Post(s)
Liked 162 Times
For a time, I was shopping ebay for a five speed 14 x 28 Regina freewheel for my '72 Raleigh International. I eventually found one, but I also noticed it was common to see the Regina freewheel mechanisms for sale by themselves.
Or.....
Or.....
Quoted: 19 Post(s)
Liked 7 Times
You can flush out any crud with wd40 then re-oil.
Best to remove the freewheel (using tool-in-bench-vice method), place small cog down in a small plastic tub and introduce the fluids though the rotating gap.
