shared lane/bike lane idea
https://www.youtube.com/watch?v=2oH4u8Xop5c
An interesting video showing driver behavior when bike lane lines are dropped completely near intersections.
Cat 2 Track, Cat 3 Road.
"If you’re new enough [to racing] that you would ask such question, then i would hazard a guess that if you just made up a workout that sounded hard to do, and did it, you’d probably get faster." --the tiniest sprinter
Arizona Dessert
Quoted: 5345 Post(s)
Liked 2,169 Times
Where is the bike lane stripe dropped? I saw a continuous line which seems to be up to the left turn.
What I saw was motorists merging partly into the bike lane to make the left turn. A good thing.
Even with the cyclist present, the taxi merged behind them.
It looked like the cyclist was not making a left turn (I didn't see them thru the turn like I could see the other vehicles.) This is a case where the cyclist should not have been far left in the bike lane to avoid a possible left hook.
Al
Al
Conservative Hippie
Looks to me like every car "weaving through the bike lane" was turning left at the next intersection. Just like the drivers are supposed to do when turning across a bike lane, depending on state or local ordinance.
Crankenstein
Bikes: Novara Randonee (TankerBelle)
Al
Al
I also didn't see anything to complain about. *shrugs*
Arizona Dessert
Liked 2,169 Times
The whole point seems to be about the 2nd intersection in the distance where most left lane vehicles are making a left turn and the BL stripe appears to continue.
Al
Crankenstein
Read the comments on the clip... it sounds like there's no painted lane before where the camera is positioned.
Where a "shared" lane becomes a true bike lane, cars veer every which way on every light cycle, not understanding where they are supposed to be. "Shared" lanes might be useful, but they can't be on-again/off-again with real bike lanes.
OK, I actually ride that intersection every day, so I can comment directly about it.
That block is actually OK, and cars, generally respect that bike lane. They're even OK, in the presence of bikes, with respecting the shared lane between Brodway and Lafayette. The problems are, as is demonstrated in the video, that the alternating one-way north-south sidestreets make for some sloppy lane positioning.
There are way worse places in NYC.
What I will say, though, is that tis block and Lafayette share a similar problem...NYC hs a mandatory BL law...but in the absence of BLs, the law is as close to the right as is practicable. But a lot of the newer BLs...both the one on Grand and the one on Lafayette included... are striped on the left. There's a little bit of a disconnect- as always, I end up what is most practical, as opposed to what's legal, strictly speaking.
To be clear....
Grand west of Lafayette is a "shared lane." That is, a traffic lane with a double chevron/biker ideogram but NO lane stripes per se. East of Lafayette on grand, there is lane striping in the traditional sense.
Liked 12 Times
Left side bike lanes are ridiculous, imo. I have a real hard time understanding how anyone could think that's a good idea.
R.
totally louche
Bikes: the ever shifting stable loaded with comfortable road bikes and city and winter bikes
Liked 10 Times
left side bike lanes can work fine on split boulevards. less turning traffic and no parked cars across median split, tree calmed boulevards. there's one in seattle along a split boulevard, a mile and a half long or so, that's the full width of a traffic lane. at intersections there's a merge zone, and the bike lane is then striped to the right of left turning traffic.
this left hand bike lane does make sense.
Arizona Dessert
Liked 2,169 Times
Left side is fine, at least relative to the fineness of bike lanes.
But there are two things about this design that are wrong:
1. It is a door zone bike lane
2. The stripe does not exist (as best as I can tell) before the 1st no-left turn intersection, but it does exist after the 1st intersection up until the 2nd one where left turns are possible. Either there should be no stripe between the 1st and 2nd to continue the no bike lane stripe implementation, or there should be a stripe before the 1st and the stripe between the 1st and 2nd should end (or become dashed) at some point before the possible left turn.
Al
Al
totally louche
Liked 10 Times
al, i thought that's exactly the scenario in the NYC bike lane- the bike lane ends before the first intersection, there's ambiguity in traffic crossing the near intersection as it rolls towards the continuation of the bike lane in the near distance.
I wonder how much of a problem it is really? sounds like some posters here that live in NYC think it's less of a problem then some of the worrywarts posting here would have you believe.
Arizona Dessert
Liked 2,169 Times
Al
On the east (far) side of grand? Yes, it's a normal-for-NY oneway doorzone bike lane. on the near (west) side? See below.
Al
Al
As an aside, I think NYC is now striping any damn sidestreet they can to get the numbers up...my current favorite is the nearly useless bikelane they've painted on Charlton between sixth and hudson... two blocks long, and on blocks that are nearly always permanently blocked by trucks loading and unloading, forcing all traffic to squeeze through however it can (including, sometimes, on the sidewalk!)
Bikes: who cares?
Laika - I thought NYC put the bike lanes on the left to avoid double parkers on the right. Also, in Oregon, you are allowed to be as close as practicable to the left side of the road as well as the right side on one-way streets, is NY law different on this?
Liked 12 Times
There is at least one in downtown Seattle which I thought was really poorly conceived and I found no good reason to be in it, which has been my typical experience with left hand bike lanes in downtown areas. I won't lose any sleep over it though.
Robert
The street depicted is a one-way...there are likely to be double-parkers on either side, and obviously you can't (or at least don't) get leftwards BLs in 2-way streets. I've always read NYC cycling law as being mandatory BL use/as close to the right as possible but admit I could be out of date or mistaken on that part.
OK, I was wrong!
—34 RCNY 4-12(p)(3): Bicycles permitted on both sides of 4O-foot wide one-way roadways. Any person operating a bicycle upon a roadway that carries traffic in one direction only and is at least 40 feet wide may ride as near as is practicable to either the left or the right hand curb or edge of such roadway, provided that bicycles are not prohibited from using said roadway.
State law (as close to the right as is practicable) is superceded by city law in this case.
