Help me spend $70
Help me spend $70
For some background, please see my last thread "Getting my bike Saturday!". I basically have $70 in Scheels gift cards that are available to spend above and beyond my bike, helmet, water bottle and cage. My family is getting me most of the cold weather gear I'll need for fall/winter riding since my birthday is on Sunday. Other things I've thought about getting include gloves (although I could probably get by with regular winter gloves for a while), headlight and rear blinker and some sort of saddle bag for a cell phone and small first aid items. I've heard that I should get a good multi-tool and tubes and other bike emergency items too.
I'm still a newbie, and am starting from ground zero. Knowing what you know now about biking, what items would you invest in first?
Thanks for your help!!
Quoted: 765 Post(s)
Liked 1,735 Times
Pedals seem like the next item on the list. Also, I know you can't use the gift card but look into one of these. www.roadid.com
Downtown Spanky Brown
Bikes: Motobecane Phantom Cross Pro Kona Lana'I
First a Headlight and blinky because its getting dark early and you should be thinking about your safety as well as compliance with local laws, then a seat bag. Put a patch kit, pressure gauge, tire levers, and your cell phone in it. If possible try and scrounge up the extra money for a frame pump, they can be had pretty cheap on Nashbar. Nothing is worse than being stuck with a flat when your miles away from home with no one to call.
A set of lights and blinkies might go for about 30-40 bucks depending on light source (LED, xenon etc.), a seat bag should be 10 bucks, pressure gauge should be 3 bucks, patch kit with levers should be about 5 bucks, frame pump will run 20 bucks (currently on sale at Nashbar) Total: 68-78 dollars.
Free Tip: If you get a seat bag, use a seam ripper to remove the Velcro straps that attach it to your seat stays. Once removed use wire ties to secure the bag to your seat, just fish them through the strap eyelets and around the seat stays. Total: 2 minutes of your life
Bau
Bau
On my TARDIScycle!
Bikes: Trek 520, Trek Navigator 300, Peugeot Versailles PE10DE
Quoted: 5 Post(s)
Bau
Bau
Agreed...besides gloves, with winter coming you really need to be visible. Planetbike's Superflash is probably the best red blinky led and can be attached nearly anywhere. It's more of a hang on than a "bolt on".
For that money, you won't be able to get a "real headlight" to be able to "see" at night, but you can get a decent headlight to help you "be seen".
Destroyer of Wheels
How heavy are you?
I recommend these for pedal upgrades The stock plastic ones are probably crap and you don't want to be stuck not being able to ride because the pedals broke.
The Almighty Clyde FAQ || Northeast Index
eTrex Vista References || Road Reference
It's the year of the enema!
The seat bag that I purchased originally used velco that fed through two plastic eyelets, you would then cinch the velcro around your seat stays (at least I think they are called seat stays, those little bars that run underneath your seat towards the back) to hold the bag in place. The problem I ran into was once the bag was loaded with patch kit, tools, wallet, and cell phone the velcro straps would come undone due to weight and being jarred around. This left my bag just hanging on by the velcro around the seat post. So I used a seam ripper (yes I own one...I sew) to neatly remove the stitching that held the velcro strap to the top of the bag. I then took two nylon zip wire ties to attach the seat bag to the bars nipping the extra length of the tie off, it wont let loose again .
Triathlon in my future???
Bikes: Junk, that is why I am here. :-)
I use my seat bag on multiple bikes, so I like the velcro. I don't carry the world in the bag, so I may not have the same problem, but I have used it for about 600 miles and never had a problem with it. Maybe it will cause me grief later, or maybe the quality of the velcro is different.
Good idea for people having problems though.
2007 Jamis Ventura Comp
2006 Jamis Explorer 2.0
2000 Specialized Hardrock (bought used)
Swim, Bike, Run and sounds like fun
Bikes: '08 Surly Cross-Check, 2011 Redline Conquest Pro, 2012 Spesh FSR Comp EVO, 2015 Trek Domane 6.2 disc
Quoted: 5 Post(s)
Liked 7 Times
bautieri,
The seat rails are the bars underneath the seat where you attach it to the post. I'm thinking this is what you were meaning.
The seat stays are the frame tubes on the rear triangle, leading from the rear dropouts up toward the seat.
"I feel like my world was classier before I found cyclocross."
- Mandi M.
- Mandi M.
This morning, 301.5 lbs.
Keep in mind, initially I'm looking for stuff that I will find at Scheel's to use up the last of the gift card. Unless necessary, I don't figure on buying too much more stuff until it starts to get warmer out again.
Of course today it's sunny and 52°, and I don't have my bike yet. I think it's supposed to get colder, cloudier and wetter on Sunday
Ah, thats the name I was looking for . Thanks for clearing that one up.
Bau
Bikes: Lemond Chambery/Cannondale R-900/Trek 8000 MTB/Burley Duet tandem
Wow! Bautiere, what kind of seatpack do you use? I have Jandd, Fox and Trek seatpacks. Never had problems with them that made me go thru that kind of trouble to keep it on!
Destroyer of Wheels
Yeah, I have Nashbar and Pricepoint 135 cubic inch filled to the gills and never had them break. I also have a luggage rack on all my bikes so if it does break it won't get into the wheel.
Quoted: 19 Post(s)
Liked 7 Times
Fenders can make riding on wet roads more comfortable and they keep you and the bike clean. The Rockhopper may need MTB style clip-on ones although you can fit a full-length one to the rear.
The stock tyres are off-road knobblies. If you want to use this bike for commuting or road riding, switch them to a kevlar-protected slick pattern; 1.5-1.9" is std width for road riding.
You can carry stuff in a backpack for a couple of miles. Carry a pump, spare inner, puncture kit and small multitool and practice how to use it in the warm. For longer rides and heavier loads, a pannier/rack system is better. The RH frame comes fitted with proper pannier eyelets so dont mess about with seatpost racks, use the real thing.
The stock alloy pedals are good enough, sometimes they fit throwaway plastic ones. Toe clips will really add some efficiency.
You dont need special cycling gloves in winter, any decent winter gloves will do.
Bikes: Cannondale Furio Specialized Allez Pro
Liked 5 Times
If you are looking for something to cover yourself and not worry about it getting dirty/wet some Carhartt insulated bibs to keep you warm and your clothes clean.
If you can get it there those inflators that use the CO2 cartridges are nice to get you going quick again. I find with slime in my tires I have next to no problems with flats.
If you get much snow studded tires are something to think about but $70 will only buy you one decent one.
One other cold riding tip is to dress about ten minutes before you leave to give your body a chance to warm up you clothes.
On my TARDIScycle!
Quoted: 5 Post(s)
The seat bag or the zip wire ties?
I understand why you would do that if you had that problem, but I've never had that problem. How heavy is that bag of yours?
Yep, I'm in Iowa (somewhere between Marshalltown and Waterloo/Cedar Falls). I don't know how long into the winter I'll try to ride yet - probably until it starts getting icey.
How the heck do you bike in insulated Carhartt bibs??? I've got a set that I wear when I'm plowing the driveway with my garden tractor, and I don't see how you could get on and off the bike with them on. Then again, mine are the "arctic" ones with a solid inch of insulation - I start to sweat just sitting on the plow after about 30 minutes, but it's better than being cold.
Liked 5 Times
Be careful of your chain ring ripping apart your pants. I usually take some duct tape and put it over the seam to prevent that from happening.
If you have any questions pm me and I will give you any suggestions that I can think of for riding here.
Seeing that you are 300lbs, I'd invest every penny, maybe more into good cycling shorts/ Maybe even a good saddle. Most stock saddles aren't too good to start with. I have problems with them at 240.
Plus good saddles may start at $75 and good shorts can be $100 minimum. If you arent comfy on the bike, you aint gonna like it and you will quit riding!
Quoted: 765 Post(s)
Liked 1,735 Times
What is this for? I'm not questioning it...just curious as to what the purpose is?
Quoted: 765 Post(s)
Liked 1,735 Times
Damn, 135 ci, you could carry a sink in that damn thing. I have a 80 ci on my hybrid and I still have room after I have my 19 multi tool, a tube, repair kit, 4 co2 cartridges, CO2 pump, tire tools and my cell phone.
Bikes: Old Bike: 1975 Raleigh Delta, New Bike: 2004 Norco Bushpilot
Liked 5 Times
There are two pumping technologies, manual and CO2. Manual consists of a mechanical pump, that you attach to your bicycle, you grab each end separate them a short distance, then push back together, repeat until the tire has enough air. There are Mountain bike pumps, which are good for lower pressure (below 6 bar ~90PSI), and road bike pumps, which are good for higher pressures. Lower pressure pumps move more air at a lower pressure, high pressure pumps move less air at higher pressures.
CO2 pumps consists of a compressed CO2 cartridge, and an inflater that moves the CO2 into the tire. The big advantage, no mechanical pumping, but you need to carry enough cartridges. It's not uncommon to forget you used your last cartridge, until you go digging through you bike bag looking for one, and don't find any. Best to buy a box of cartridges, and keep a certain number in the bike bag, then when you use one, you replenish your supply from your box. The number of flats that can be dealt with, with a mechanical pump is ∞ + 1. Some folks will carry both a mechanical pump, and a CO2 inflater, if you run out of cartridges, you can always use the pump.
Also a good idea, is to buy a floor pump with a gauge on it, before every ride, you check that the tires are at the proper pressure, this is typically the maximum pressure marked on the tire sidewall. Don't worry that you might be a few pounds over, the maximum pressure is a balance between what the tire engineers know, and the tire manufacturer's lawyers think. It's not uncommon for a tire to be engineered for 180PSI, but marked 120PSI. Also don't worry if you pump your tires to 120PSI, and 2 or 3 days later you go to ride, you find it's 80PSI, that's perfectly normal, rubber tubes are not completely air tight.
Buy a pair of the Scheels label bibs. They are made by Primal Wear and I find them to be every bit as good as my Pearl Izumi Ultrasensors. They sell for $45 right now at the WDM Scheels.
Ummm what the heck is WDM Scheels????.... I bought some PI Ultrasensors a few months back, I hate them. They are really skimping on material now,IMO! Been using them for the last 6 years, were always great but no more! Last pair ran me $100. I bought the PI Quest model out of curiosity ($45), padding much better than the $100 US's!
I'm not a bib guy but maybe Scheels have similar short models?
