Changing Marzocchi oil and springs
Can anyone give me some pointers on how to do this. I can't believe that their tech manual has nothing on how to do this.
I have a 2003 Z1 FR QR20
I want to change the springs to the extra heavy duty and top off or raise the oil level.
Thanks
Thanks
un do the top caps (21mm wrench)
push forks down
remove springs
insert new springs
add oil to legs, making sure it equal to the other leg
replace top caps,
job done
push forks down
remove springs
insert new springs
replace top caps,
job done
push forks down
remove springs
insert new springs
replace top caps,
job done
push forks down
remove springs
insert new springs
replace top caps,
job done
What are the aluminum hex bolts for on the bottom of each fork leg? Based on your description they are to be left alone?
thanks for your comments and help.
Part of the furniture
Bikes: Specialized RH, Scott Unitrack
Yeah can you be more specific? I have the same question and i need guidance since marzocchi ommited to put service instructions in the manual for 2003 Z1 . Also how much oil should be put and of what weight? IS there any complete service manual with breakdown instructions available? Marzo site doesnt have anything relevant and they also denied to send me one.
