Campy set up anyone?
Bikes: Redline d660, '85 Schwinn Peloton full new ultegra, IRO robroy ss cross bike
Ive been think about setting up a cross bike full campy and there are a few problems i have run into... campy has a 135 BCP and all (salsa and fsa) chain guides are set up for 130. Is there anybody who makes chainguards/guides that are compatable?
If anyone knows another problem i might run into with campy stuff please share
Thanks
Thanks
Though it's been said that you can't, I was able to fit a generic 110bcd chainring on my Veloce UT Compact crank. Photographic proof here. I don't know if it applies to Centaur and up, though. It does mean you could use any 110 chainguard and ring on a Veloce UT Compact, which I've found to be a darn good crank.
Don't smoke, Mike.
Bikes: Devinci Tosca, IRO Rob Roy
cyclocrossworld has campy chain guards 135mm bcd.
Get on a cross bike.... you'll like it ;)
i think i might have to run none campy...too bad
oh well. it is very true that campys compact stuff is 110 bcp but even then campy still has that one odd arm to keep them exclusive. so i guess non campy it will have to be. I have seen this company called stella azzurra that makes a carbon crankset that i have heard good things about but i am a little fearful of setting a carbon crankset on a cross bike. after all we all have heard of carbon wheels, bars etc breaking. some thoughts..
Bikes: Witt Custom / Cinelli SuperCorsa / Raleigh Cross, nothing original / Very old Bianchi Mtn Bike
Back up... if you're talking about ring guards, are you planning to run one ring up front? If that's the case, then it doesn't matter what crank you have.
Bikes: Dawes Kalahari, Puch Prima Super Sport, Graham Weigh 853
I think the old, square taper Mirage, Veloce and Centaur cranks have a normal 110bcd. If you need an Italian alternative, may I suggest the Miche Grand Tour? Miche do a lot of rings in 110bcd that you may be able to order with it. This will probably be my crank of choice when the time finally comes
Otherwise, Cyclocross world has a 135bcd guard. Or you could run the inner two rings of a triple..
