Shimano FD, Campy shifter ...will it work ?
NE Roadie
Bikes: 2006 Colnago C50, 2003 DeRosa Merak, 2001 Litespeed Vortex, 2001 Lemond Buenos Aires
Can use use a Shimano triple front derailler (FD-6603) with a Campy chorus shifter? Or to put it in another way, can you replace a Campy triple FD with a Shimano triple FD? Thanks in advance.
The problem is not with the Campy. shifter, it is with your crankset. If your Campy crankset is a 52-42-30 , the FD-6603 (made for 52-39-30) won't work, the back lip/flange of the dérailleur won't clear the 42T, and if you re-adjut it to clear the 42T, it will be to high for the 52T. Obviously, no problem if your Campy crankset is 52-39-30.
Bikes: Lynskey 210R, Cannondale CAAD2 MTB
I started to take exception to this since I have a Specialized Allez Elite which has a Sugino triple crankset, 52-42-30, and a Shimano 105 FD. Then I realized that it is 9 speed and Shimano offered a 52-42-30 crankset at that time. Now, with 10-speed, they offer a 52-39-30 crankset. Are the FD's that much different for 9 speed vs 10 speed? I am surprised that they would change the chainring sizes this way just due to the chain getting a little thinner.
Thanks,
Ted
Thanks,
Ted
Gone, but not forgotten
Bikes: See: https://sheldonbrown.org/bicycles
Quoted: 24 Post(s)
Liked 6 Times
See also: https://sheldonbrown.com/front-derailers
and: https://sheldonbrown.com/speeds
Sheldon "Yes!" Brown
Quoted: 24 Post(s)
Liked 6 Times
The so-called "9-speed" triple front derailers are optimized for a 10 tooth jump middle/big.
The so-called "10-speed" triple front derailers are optimized for a 13 tooth jump middle/big.
Chose on the basis of you chainring sizes, not the number of speeds on your cassette.
Sheldon "Marketing" Brown
