Track Sizing
IRL Banhammer
Track Sizing
So I want to do some track racing, maybe some local 'around the block' type fixed races. Not looking for a commuter bike, so the geometry can be steep, but also have a budget.
Right now I ride a '99 Trek 2500 54cm, with a 54.5 TT. I've noticed that other frames in the equivalent size have a much shorter TT length, whether or not they're compact. For example, the Trek T1 in 54 has a 53.6 TT, while the 56 has a 54.3 TT, much closer to the TT length I ride now. My actual inseam is 32"
For other information, I ride with a 120mm Ritchey WCS 4-axis stem (in case you were curious of the +/- degree), and WCS bars (if you were wondering the total reach). I have found this pretty comfortable. Would not like to go below a 100mm stem for the bike I end up getting.
Not so much specifically for me, but how should sizing go? Same as road? I saw a thread where people suggested same or even smaller (depending on your riding type) sizes, but never 'bigger'
Quoted: 43 Post(s)
I ride pretty much the same size as road. Totally different frames now though-- my road bike is traditional big triangle and the track bike is compact. The measurements to where I connect to it are pretty much the same.
Bikes: Pedal Force QS3
In the past I went 1cm shorter in the top tube for a track sprint bike. I'd stay the same for a points bike. You could just move the seat forward to decrease the reach.
15% Hammer Nutrition Discount Code
