Go Back  Bike Forums > Bike Forums > Winter Cycling
Cheap mittens any good?
Winter Cycling Don't let snow and ice discourage you this winter. The key element to year-round cycling is proper attire! Check out this winter cycling forum to chat with other ice bike fanatics.
Old 11-07-07, 09:11 AM
Quoted: 16 Post(s)
Liked 4 Times in 3 Posts
I am thin and my hands get numb really fast when it is below 40 F. I have been using $40 ski gloves, but from what I read, mittens are far better. Will these do the trick? My walmart doesn't seem to stock mittens.
$10 wool mittens
duke_of_hazard is offline
Old 11-07-07, 10:46 AM
In Real Life
Machka's Avatar
Bikes: Lots
Quoted: 3203 Post(s)
Liked 596 Times in 329 Posts
Oh yeah ... I love those! I have several pair. Check the hunting department of your local Walmart.
Machka is offline
Old 11-07-07, 11:04 AM
Quoted: 16 Post(s)
Thanks, but will these work in 10 - 30 F weather or do I need wear some additional coverings/linings ?
Old 11-07-07, 11:20 AM
Not the Slowest's Avatar
Bikes: 2002 Seven Axiom
Quoted: 11 Post(s)
Duke,
If you are riding in temps 10-40 you have to deal with 2 sets of gloves.
You did not tell us how long you plan on being out on the road, but here goes for my commute which is 25 miles each way:
At the 40-45 range the mittens you saw should be fine.
I use a thin glove and put that over my road half gloves and remove if needed. You can also buy in a garden or hardware store cheap cotton gloves with rubber palms and they will do the job for say $2.50 a pair. The key is that you need some grip so you do not slide off your brake levers.
Next: 10-39 degrees - Ski gloves could work, but they should have rubber palms or again the grip issue is a problem. If you are cold with the ski gloves, perhaps a better choice in the 10-30 range are Lopster gloves made by Pearl Izumi and a few others. They are pricey but work.
Many times your hands can be cold because:
a) Gloves are too small-tight
b) You are gripping the handlebar with a death grip, cutting circulation.
c) Your hands are wet from sweat
d) You just have cold hands
You can also get hand warmer inserts, also battery operated warmers.
Bottom line 10-25 is an entirely different world from 26-40 degrees
Hope this helped.
Not the Slowest is offline
Old 11-07-07, 11:22 AM
Bikes: Trek 4300 X 2. Trek 1000, Trek 6000
I have these: https://www.glacierglove.com/online_store.htm
Those look fairly similar but I haven't worn them. I wear mine down to -5F with no trouble. That is the coldest it gets here. I wear a glove liner under mine so skin is covered even when mitt is flipped open.
Portis is offline
Old 11-07-07, 12:17 PM
Uber Goober
StephenH's Avatar
Quoted: 190 Post(s)
Liked 41 Times in 32 Posts
For snowshoeing, I had some wool mittens that generally worked fine. It all depends on your metabolism, how hard you're working, wind speeds, etc. I also had some "Zero" brand waterproof mittens, but they made my hands sweat- the regular wool mittens let some air through. Try 'em and see what works.
Check REI if you have one in your area.
StephenH is offline
Old 11-07-07, 03:21 PM
In Real Life
Machka's Avatar
Bikes: Lots
I second the comment that for that temperature range you will need at least 2 pairs of hand coverings.
I cycle in quite a range of temperatures and I've got a whole box full of hand coverings for every occasion.
I use the mini-gloves (0.99 at Walmart) under my cycling gloves for when the temps are about 30-40F. I've got several sets of mini-gloves which I carry in my jacket pockets, trunk bag, handlebar bag, etc. all the time. You just never know when it is going to get chilly.
I move into flip tops a bit below 30F.
I'll put a polypro liner under the fliptop for temps even colder.
I'll break out the ski gloves for colder temps.
I'll put a polypro liner under the ski gloves for even colder temps.
I'll break out the snowmobile mitts for when it gets really cold.
And I'll put a polypro liner under them too for even colder temps.
My cold weather gear fills several bins.
Machka is offline
Old 11-07-07, 07:49 PM
Bikes: '07 Pista, '09 Fantom Cross Uno, '8? Miyata, '67 Stingray, '0? Zoo mod trials, Tallbike, Chopper, '73 Schwinn Collegiate, '67 Triumph Chopper, '69 CB350, '58 BSA Spitfire, '73 CB450
I use those with a cheap pair of little gloves under. Works quite well.
ianjk is offline
Old 11-08-07, 07:19 AM
JonathanGennick's Avatar
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 685 Post(s)
Liked 55 Times in 37 Posts
I couldn't do mittens very easily. My winter bike doesn't have thumbshifters. I need a finger for shifting.
You might give a look to cross-country ski gloves. I just picked up a pair Rossignol XC gloves the other day. They are thin and have a grippy palm and fingers. They have a layer of thinsulate insulation for the back of the hand. The palm is either not insulated, or it has a much thinner layer. For the short, one to two mile trips that I do around town, I'm pretty sure those will take me down to at least the teens. I'm looking forward to testing that theory.
JonathanGennick is offline
Old 11-08-07, 12:08 PM
In Real Life
Machka's Avatar
Bikes: Lots
I use mittens and my bicycle has ... I guess they are called brifters ... the shifters behind the brakes.
Machka is offline
Old 11-08-07, 12:50 PM
totally louche
Bekologist's Avatar
Bikes: the ever shifting stable loaded with comfortable road bikes and city and winter bikes
Liked 10 Times in 9 Posts
go modular. I like leather gloves to about freezing, wool gloves under leather work gloves for biking in snow temps.
Overmitts when it is hella cold.
Bekologist is offline
Old 11-08-07, 02:28 PM
badmother's Avatar
Quoted: 317 Post(s)
Hello. Wool is the best. I make my own wool gloves. Use knittingwool that is not "superwash", use pins that is much thicker than normal. Make them too big and too loose. Then wash them in the washingmashine 2-3 times with your jeans or similar. Makes them wery thick, almost like thick woolen material and almost windproof also. If wery cold or hard wind use windproof material mittens on top. Can be made or bought. I bought one pair for my son, they called them "snowboard mittens". Also you can buy mittens made for hunters, they need the triggerfinger free, so they are mittens with the thumb + one finger.
badmother is offline
Old 11-08-07, 03:26 PM
Maybe you ought to read the thread a little more thoroughly. We are mainly discussing flip mittens here.
Portis is offline
Old 11-08-07, 09:20 PM
Quoted: 685 Post(s)
Sorry about that Portis. My bad. I didn't mean to derail the discussion.
Old 11-18-07, 08:40 PM
I love my cheap Thinsulate fleece flip mitts for their flexibility---my hands warm up and get cold quickly, and of course sometimes you need to use your fingers and sometimes you don't; and the mitts meet all these demands. They are definitely warm enough for everything the Pacific Northwest has thrown at me, but ymmv if you live someplace that has a real winter.
mander is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
