Red cable housing
Bikes: Trek 1000 and Lotus mixte
Red cable housing
After seeing a pic last week, I wanted to put red brake and shift cable housing on my red Lotus mixte. The mixte is fire engine red. I emailed Harris Cycles to ask if their cables were fire engine red instead of an orange red. Their reply: The red of the housing varies. The shift is different from the brake. Neither is bright red. There is almost no possibility the red of the housings will match any existing red you've got. The odds are very poor.
So, am I out of luck? Anybody have any experience with this?
I bought JagWire red brake and cable housings and they match pretty well, but I'm not going to say the color is exactly what you need. If you want I could send you a short clipping and you could compare it to your frame. My LBS ordered it for me at a pretty reasonable price
I bought Sinz brand BMX pre packaged brake cable sets for my Voyageur. If you have friction shifting it will work on brake and shifters both. It's also lined housing, and a good price. You will probably need at least two packages. Two did my Voyageur but it also has bar cable along the top tube. Three will probably do the trick if you have stem shifters and full length brake housings. They come with the brake cables, so you will need two bare shifter cables. Any bike shop should have those.,,,,BD
https://www.bmxracingnw.com/sinz.html
So many bikes, so little dime.
On a friction shifting bike, the housings from brake cable work just fine. Indexed shifting bikes need the stiffer longways made housings. If your bike shifters click when they shift, then you'll need the special
shifter housing. The actual cables themselves are different for shifter and brakes, thus you'll need replacement cables that any shop will carrry.,,,,BD
stringbreaker
Bikes: specialized crossroads hybrid 2006 Raleigh Cadent 2 1971 Schwinn Varsity, 1972 Schwinn Continental, 1977 Schwinn Volare (frame)
Quoted: 9 Post(s)
MMM I got mine from Harris and they matched nearly perfectly but there may be variations depending on the die lot also there are a lot of different shades of red, but like I said mine are near perfect. I see lickbike is stocking the red ones again too. Mine are Jagwire. The derailleur cable is a stone cold B***H to cut unless you have the right cutters. If you get the reinforced cable housing take it to your LBS along with the old housing and have them cut it to length the file the ends and use something like an awl to open up the ends
Bikes: Forty of them
Quoted: 99 Post(s)
Liked 33 Times
My experience is also with Jagwire (by way of the LBS) and it fit the bill for me. I realize the camera/lighting thing makes this difficult, but here are some photos which come close-ish to the true color of the stuff I got.
Bikes: '86 AMBROSI / C RECORD. PINARELLO MONTELLO / FRAME, FORK.
Just a thought . . .
Automotive bumper paint for the 'new', plastic bumpers.
Are there not many 'shades of red', for/from different manufacturers?
Comes in spray or brush for application?
Dr D?
Regards,
J T
Dr D?
Regards,
J T
feros ferio
Quoted: 1391 Post(s)
Liked 1,322 Times
OK gang, should I put red or white cable housing on this bike? I am repainting the red head tube, including the lug cutouts, to match the original red on the seat tube, and I am preserving what is left of the off white paint on the forks, top tube, and downtube. I currently have white cable housing left over from the Capo #1 restoration, but I am beginning to think red might look cool, although I shall probably end up with three different reds on the toe clip straps, the frame, and the cables.
Spin Forest! Spin!
Bikes: I used to have many. And I Will again.
Quoted: 7 Post(s)
Liked 11 Times
If you're repainting the frame, I'd go with red.
White is too generic on a multi-colored paint job. IMO only looks good on a white frame.
www.theheadbadge.com
Quoted: 2420 Post(s)
Liked 4,381 Times
Dolce far niente
Quoted: 20 Post(s)
Liked 16 Times
I'm with Kurt - white cable housing might really make that lipstick-red Lotus "pop".
"Love is not the dying moan of a distant violin, it’s the triumphant twang of a bedspring."
S. J. Perelman
S. J. Perelman
Liked 4,381 Times
feros ferio
Liked 1,322 Times
I resemble that remark.
Bikes: 2005 Specialized Allez Comp, 1970-ish Reynolds 531 Gitane Tour de France
Red cables with white bar tape. (Nevermind that it gets dirty... It looks swell.)
