Good hub, bad rim- best way to separate the two?
I found a 26" 32-spoke wheel with a brushed silver USA-made GT hub this afternoon at the thrift store for $5.00. I have an unbuilt matching rear hub, so I'm going to have them built into a 700c CX wheelset. The wheel already has one broken spoke and the rim doesn't look like it's in very good shape, but the hub's in great shape and the spoke holes look fine. Can I just take some needle-nose pliers and cut the old spokes, or will I risk damaging the spoke holes on the hub by doing it this way? I know how to use a spoke wrench, but don't own one. If it IS safe to just cut the spokes, is there any order I should follow (one side, then the other, for example)?
Thanks in advance, and any info on the hubs would be greatly appreciated- they look pretty much like this one, except they're made in the US.
use your best eye
Bikes: '75 Bertin, '93 Parkpre Team 925, '04 Kona King Kikapu, '05 Bianchi Vigorelli
Just cut away in the middle of the spokes, working your way around- wear eye protection and lay the wheel down away from you so the nipple ends of the spokes don't come flying out of the rim and hit you or someone else. This can happen until most of the tension is relieved from the wheel, which will be when you're nearing halfway around. Leaving the rim strip on or wrapping with strong tape can help contain the spoke ends. Most common pliers/side cutters are a bit weak to deal with the stainless so you may have to work it. I use high leverage hardened side cutters for this. Also, some of the Vice Grip pliers have OK cutters built in.
"I tell you, We are here on earth to fart around, and don't let anybody tell you any different." - Kurt Vonnegut jr.
Thanks! I'll start on it first thing in the morning. I won't have any problems with the spoke flying out- the tire is still on the wheel. I'll wear the goggles anyhow, as Murphy seems to live right next door, or pretty close.
Quoted: 2026 Post(s)
Liked 1,096 Times
Even if you have to use a pair of pliers or a Vise-Grip as a spoke wrench, I'd loosen the nipples a turn or two all around before cutting the spokes. It's safer and easier on the hub flanges.
BTW, Murphy doesn't live next door, he lives in the same room you do.
Sir Fallalot
Quoted: 9 Post(s)
Liked 13 Times
I might be too conservative (i.e. I like to keep my stuff), but I think spokes are made of some rather strong steel, and cutting some 30 or so of them might cause considerable wear to any tool you might have. I would just unscrew the nipples with a screwdriver, if I were you.
cycle-dog spot
Bikes: Look, Niner, Ellsworth, Norco, Litespeed
Very seriously, unless you are dying to build a wheel, you can pick up pre-built something from Performance (or similar) for less money.
-Z
-Z
use your best eye
Good point, yes, very hard on the cutting tool. Thats why I use these Klein cutters, high-leverage and hardened jaws:
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
I have cut about 1800 spokes in a day with a single tool already worn, and is sill works the same as before. Also if you cut the spokes as close to the hub as possible, it makes removing them a whole lot easier.
+1 on cutting spokes close to hub. then you have 1/2 to 1" stubs to wiggle out of the hub, not 6" things you have to untangle.
also, put the rim over a garbage can and "aim" the spoke you're cutting downward. the spokes shoot down unless you have a rim strip or tire glue holding it in place.
+1 on cutting a lot of spokes using that pictured tool or something similar (wire cutter as part of pliers, for example - what else will you cut with that?). whatever you do, do NOT cut using cable cutters (shimano, park, etc).
put the spoke as close to the pivot of the wire cutter as possible - i.e. as far down the "V" of the cutting edges. it's really not too hard to cut like that.
I'd recommend wearing gloves, the shock of cutting spokes will make your hand tingle after you cut a bunch of them.
never cut even close to 1800 spokes in a day,
cdr
cdr
"...during the Lance years, being fit became the No. 1 thing. Totally the only thing. It’s a big part of what we do, but fitness is not the only thing. There’s skills, there’s tactics … there’s all kinds of stuff..." Tim Johnson
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
cdr
cdr
Stuart Black
Stuart Black
Its amazing, a simple task and so many ways! I agree use cutters, cutting close to the hub. I always save a few spokes, sort of just incase I need one of that size, and for the memories.
i'm an electrician and those are what i use. the red handles are cheaper and softer. i use the blues handled (as pictured) that are curved for pulling staples and install the hi-leverage grips.
i cut through a small master lock the other day with no problem....better leave me the key next time .
the only way to damage these pliers is by cutting through a live wire and touching a ground. then you have an expensive pair of wire strippers .
ed rader
Don't call me sir
Bikes: 1954 Holdsworth 3 speed, 1969 Bob Jackson, 1988 Miyata Twelve Hundred (retired), 1989 Schwinn Paramount, 2004 Santa Cruz Blur Classic, 2012 Specialized P3, 2013 Specialized Roubaix Expert Disc
I know the OP implied that this hub was a front, but I just wanted to mention that if you are cutting spokes or even gently removing the rim on an older REAR hub, always remove the freewheel first. It is possible to get one off if you've already removed the hub from the rim, but I wouldn't recommend it. Cassettes are a little easier, if you have two chainwhips (for older cassettes) or 1 chainwhip and a cassette tool (for newer ones).
Not that I've ever done such a thing...
use your best eye
ed rader
ed rader
use your best eye
In trim carpentry the similar DOH! is to nail a pocket door open when installing trim. I've done THAT one a half dozen times.
Long haired freak.
Bikes: 2011 SE Old Man Flyer.
Works just fine for me.
"the bus came by and I got on, that's when it all began...there was Cowboy Neal at the wheel of a bus to never-ever land."
Liked 1,096 Times
In automotive work the same "rite of passage" is forgetting to reinstall the oil pan bolt when changing oil.
loser
Bikes: steyr, lejeune, schwinn, sears, crescent, blah blah blah.
I'm with cyccommute. I'd loosen them a couple turns first before cutting them, It might take 10 minutes longer, but why take a chance? You can probably use a screwdiver but whats the story with not having a spoke wrench? how are you going to build your wheel?
Never have worried about detensioning them. I just cut everyother one all the way around. BE SURE TO POINT RIM IN A SAFE DIRRECTION. I usually rest it over the trash can to catch the projectiles.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
Why would you cut the spokes? I just unscrew all the nipples, wrap them and the spokes up in a bundle, and put them in the 'used spokes' box. It's not a lot of work. When I need a spoke, I often find the one I need in that box. A couple times I've had my LBS cut them down and rethread them when I needed to lace up a small wheel.
