Everything is adjusted
Some times, not always, when I coast and I'm ready to start pedaling and it seems to slip a tooth and it seems to be in back. New chain and cassette, cable adjusted and I still get it once in a while. Would anybody have any ideas, thanks for any replys.
George
George
Bikes: 2005 Specialized Allez Comp, 1970-ish Reynolds 531 Gitane Tour de France
Are you running friction shifting, or indexed? Is the derailleur hanger perfectly straight? Random thoughts...
use your best eye
Bikes: '75 Bertin, '93 Parkpre Team 925, '04 Kona King Kikapu, '05 Bianchi Vigorelli
This also happens to me.
I'm going to advance a possible explanation here........sometime when you were coasting you backpedaled and there was a bit of road shock that derailed the chain from the cog where it was supposed to be. Upon starting your pedaling again, the chain had to jump back to the originally chosen cog.
Sound feasible, George?
"I tell you, We are here on earth to fart around, and don't let anybody tell you any different." - Kurt Vonnegut jr.
George
George
Bikes: 88 Fisher Gemini tandem, 92 Trek 970, 07 Nashbar Frame, 08 Gary Fisher Paragon
It could be the freehub body not latching up properly. Does the bike do any ghost pedaling when you push the bike along? Just had one of these this weekend. The freehub was toast, swapped that out with a fresh set of bearing for the axle and everything was fine.
Just a thought.
Just a thought.
George
George
