why did i super glue bb's into the heads of my stem bolts and how do i get them out?
griffin_
Bikes: raliegh "too lazy to make my own" rush hour
this sucks and was stupid
thomas masini lives
lolol
did you try goofoff or some superglue eating chemical
huffing that ish will help you recreate the mindstate in which you decided to do this
griffin_
acetone only get the stuff on top, there is glue under the bb's too
i'm gonna have to drll the ****ers out, o something
You're supposed to use hot glue, not super glue.
That way you can dig them out with an awl or something.
griffin_
¡Senor Member!
¡Senor Member!
Works
Bikes: You won't believe what's in our stable.
Did you use BB gun BBs? They're generally a softer material than steel so drilling them out won't be that hard.
If you used steel BBs, then take a hammer and punch and wail directly on top of the bearing. The glue is a really brittle acrylic, so a sharp enough impact should be able to shatter the bond. Good luck.
vasracer
Bikes: Leader LD-735TR, Mercier Kilo tt, 3Rensho pursuit(not complete)
super glue reactivates when it it heated. Try using a small torch or a pencil torch, it will give enough heat to liquefy the super glue but not enough heat to distort the aluminum.
Taking "s" outta "Fast"
o harro buttercup
Bikes: Bianchi Pista, Sting Ray Deluxe
Double Agent
Bikes: Fly Pantera, GT GTB
Wow, this thread has officially bypassed useful by route of "you did it wrong" in the direction of "let's not help at all and post funny pictures!".
