Creaking From Cranks
Old 11-27-07, 07:47 PM
mideng2m6's Avatar
Bikes: releigh fixed conversion, 70's ross conversion
Hey guys, i searched and found nothing regarding creaking. When i pedal the left crank arm makes a creaking noise so I tightened it and rode it to see if the sound went away. After 2 blocks the noise came back. Do I need new cranks or a bb? thanks in advance, matt
mideng2m6 is offline
Old 11-27-07, 07:52 PM
harrospokes!
fetch's Avatar
take off your pedals, wipe the threads and re-install. if not, check your chainring bolts to see if they're tight
fetch is offline
THIS SPACE FOR RENT
Don't continue to tighten it, this can lead to failure. Try tightening the chainring bolts, and stand up while pedaling to make sure it's not in the saddle. A huge number of creaks that sound like other stuff are actually from the saddle area, bikes are a big pile of resonator tubes so finding the source of sounds can be tough.
Landgolier is offline
Old 11-27-07, 08:06 PM
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times in 19 Posts
https://www.sheldonbrown.com/creaks.html
operator is offline
Old 11-27-07, 08:34 PM
spin
The LT's Avatar
Bikes: raleigh m-60, azonic steelhead, schwinn world sport fixed gear
I've had decent luck by taking everything apart cleaning and regreasing all the appropriate parts and reassembling
The LT is offline
Old 11-27-07, 08:43 PM
Liked 8 Times in 5 Posts
i had a similar problem on my fixed conversion. I actually ended up replacing the BB. I dont know if this will help you, but for me it made sense because when i bought the cranks from my local bike recycler, they came with a bottom bracket which was "used". When i pulled the old BB it had signs of rust and the bearings didnt feel right when i would spin the spindle. But after the replacement ive had zero creaks and it runs perfectly. The cranks in question where shimano 9-spd ultegras, 6500. hope this helps, what kind of cranks are in question ?
ksyrius is offline
Old 11-27-07, 09:31 PM
mine used to creak. The culprit on my bike was the chainring bolts. I just recently put real allen bolts through mine becuase they kept loostening up.
Jenkinsal2 is offline
Old 11-27-07, 09:54 PM
Hopeful Monster
pittmatj's Avatar
Bikes: cannondale synapse, custom frakenstein fg
My Peugeot Sprint has creaking cranks. Listen to Sheldon Brown, he knows what he is talking about.
pittmatj is offline
Old 11-27-07, 09:56 PM
Gone Tarcking. Back Later
Bikes: Iron Horse Warrior Team (tricked to high heaven), Jamis Coda Sport (frame and fork, built into CX commuter), Gary Fisher Opie Dirt Jumper,SE Lager tarck bike
Square taper cranks, I assume? Left crankarm? Could be the square hole on the crank wallowing out. I've seen it happen on a few too many bikes, including my own. I did myself a favor and replaced (upgraded) the crank/BB to a splined system.
Make sure your left crankarm bolt is sufficiently tight. Otherwise, the BB is just gonna make the hole on the crankarm bigger and more out of shape, leading to continuing loosening and eventual replacement by the frustrated rider.
geeknerd99 is offline
Old 11-27-07, 11:24 PM
Yup, and don't grease the spindle.
-Rob.
robcycle is offline
Old 11-27-07, 11:27 PM
i had to take out the 2 bolts for my thomson seatpost and grease them. that made the clicking noise go away. i had previously thought it came from the cranks, too. i figured it out by pulling/pressing hard on my saddle and found that that duplicated the noise. this may not pertain to you, but hope it may help you or someone else.
str8flexed is offline
Old 11-28-07, 12:09 AM
twiz's Avatar
Bikes: jacobs
I've had this happen and fixed it by removing and reinstalling the bottom bracket.
twiz is offline
Old 11-28-07, 12:32 AM
aka. vertical jon
WhiteCarbonDude's Avatar
Location: Anaheim, Home of the Los Angeles? Angels of Anaheim... in Orange County?
Bikes: White Carbon Token, Cannondale Mtn, 1975 Peugeot UO-8 Golden Fixed Conversion
+1 but make sure you lube the BB threads, that was my problem. I thought it was the cranks but it turned out to be the BB.
WhiteCarbonDude is offline
Old 11-28-07, 12:39 AM
Ah, but did you have to remove and replace the cranks for this?
-Rob.
robcycle is offline
Old 11-28-07, 12:49 AM
Go for the easy-to-remove-and-lubricate items first like pedals. Sounds reverberate and transfer all over bicycles...so what sounds like a bottom bracket creak could easily be from the saddle.
Pajaro is offline
Old 11-28-07, 12:54 AM
twiz's Avatar
Bikes: jacobs
No, I didn't replace the cranks. I just took it all apart, cleaned/greased everything again and put it back together.
I also use blue thread locker on my crank bolts.
twiz is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
