bought the bike, now how to maintain it?
Hi, everyone. I'm a newbie mountain biker and I just bought a shiny new Specialized Hard Rock. Now I'm looking to do all the right things to make this thing last as long and run as well as it can. So my question is: What's a good basic maintenance schedule to keep? What do you do and how often do you do it? Right now, I live in a pretty urban environment so I don't get out and dirty as much as I'd like (maybe 1-2 times/month), but I do ride a lot for transportation. What do all you experts do?
Thanks a lot for any input you can offer
Thomas
Thomas
Still kicking.
Bikes: Bike Count: Rising.
I generally clean the bike every 2, 3 rides. Change tires every 5-8 months, new chain and cassette every 3,000 miles(done this 6 times already this year.
) Rebuild for every 10 rides, change tubes every 2 months if I don't flat before then. That's what I do, but I beat my bikes up. a good maitenance routine is is clean/relube drive trasin after every 2 or 3 rides, or after every ride if it's wet out. Check air pressure before every ride. As you break components, you upgrade.
Appreciate the old bikes more than the new.
Thats a pretty heavy maintainance schedule. For a commuter/utility bike, you really dont need to mess around that much.
I lube the chain at least once a week, pref more.
An unlubed chain will rapidly wear, then it will wear down the rear cogs. Replace every 6moths-1year as needed.
You can reduce your maintainace by keeping the bike clean. Wax the clean frame to help it shed dirt. Fit fenders to keep road muck of you and the bike.
Ensure that QR levers are tight and that the brakes work and are free of embedded grit before every ride.
The rest is really a yearly service of bearings, cables.
The Hard Rock is a great bike, but for commuter use, fit some smoothe, high pressure road tyres for extra speed. Tyres should last a year or 2.
Do practice fixing a puncture/replacing the inner tube before it happens on the road.
Bikes: 1 trek, serotta, rih, de Reus, Pogliaghi and finally a Zieleman! and got a DeRosa
First thing I'd suggest is get a good book, like Zinn and the
Art of Mountain bike maintenance.
The frequency of cleaning/maint etc. will depend on how you
ride. the more you're in the muck, the more you'll need to clean.
Marty
Marty
Sono pił lento di quel che sembra.
Odio la gente, tutti.
Want to upgrade your membership? Click Here.
Bikes: '03 Fuji Roubaix Pro; '03 KleinGi Attitude; '06 Soma Rush; '04 Surly Cross-Check; '06 Soma Rush; '07 Scott CR1 / Chorus
I wipe down the bike when it's dusty, and wash it properly when it's dirty. Don't use a hose on anything other than the frame tubes and wheels - you don't want to get water in the bearings.
I lube the chain every couple of rides (twice a week on the commuter, once a fortnight on the MTB), and clean it when it's a bit grubby. On my commuter, I remove the chain and soak it in degreaser about twice a year - I do this about twice a season the MTB. I also re-lube the cables, service bearings etc about once a year. Casettes and chains I replace when the chain has stretched too much.
Everything else I pretty much replace when it breaks! Make sure you check air pressure frequently (on slicks normally every ride, but on lower-pressure MTB tires I find every two weeks seems to be ok).
Bikes: Lots
Check for loose bolts often. This only takes about 2 to 3 minutes to go over the whole bike. I can't tell you how often I find a "finger tight" nut or bolt.
L8R
L8R
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, What a Ride!" - unknown
"Your Bike Sucks" - Sky Yaeger
Center of the Universe
Bikes: Bianchi San Remo, Norvara Intrepid MTB , Softride Solo 700
Marty
Marty
Matthew 6
Matthew 6
Everyone,
Thanks for all the helpful replies. I just got on Amazon and ordered the Zinn book and will jump into that when it gets here. In the meantime, I've got your thoughts to get me started
Thomas
Thomas
