The official how to cut cables and housing without a cable cutter thread
Old 12-11-07, 02:12 AM
You don't need to buy special tools. Take a pair of lineman's pliers, or any other wire cutters, I would assume, and place them on the ground with the levers perpendicular to the floor. Place your cable/housing, not both at the same time, inside the cutting surfaces. Give a purposeful whack with a deadblow hammer or a rubber mallet. A clean cut every single time. No filing or other work needed. You are good to go.
evictionsurplus is offline
Old 12-11-07, 02:23 AM
we are 138
Philatio's Avatar
I just squeeze real hard. Man up?
Sometimes it works better (with regular cutters) to work my way across the cable/housing rather than try to cut it all the way across at once.
Philatio is offline
Old 12-11-07, 02:25 AM
yo yo yo yo yo
if you have a dremel with a cutting wheel (but somehow no wire cutters) that works great.
trons is offline
Old 12-11-07, 02:37 AM
:jarckass:
deathhare's Avatar
Who has brake cables?
deathhare is offline
Old 12-11-07, 02:48 AM
Elitest Murray Owner
Mos6502's Avatar
Bikes: 1972 Columbia Tourist Expert III, Columbia Roadster
Liked 3 Times in 2 Posts
There are special tools for cutting cables housing?
Mos6502 is offline
Old 12-11-07, 07:19 AM
Car-lite, Car Blight
Eulogy13x's Avatar
Bikes: Several
I'm gonna have to try this. I always use electrical wire cutters by hand, and I always mangle the cables. And $40 seems kinda expensive for something I use like, once a year. Thanks for the tip!
Eulogy13x is offline
Old 12-11-07, 10:19 AM
live free or die trying
humancongereel's Avatar
Bikes: bianchi pista workhorse, cannondale r1000, mountain bike fixed conversion
bolt cutters.
humancongereel is offline
Old 12-11-07, 10:22 AM
Tinkerer since 1980
TheBrick's Avatar
Bikes: Coppi racer, Old school BMX, some random a fixed wheel convertion
Lump hammer + anvil + cold chisel.
Not a set of tools to take with you on the road mind you.
TheBrick is offline
Old 12-11-07, 10:28 AM
I used a combination of wire cutters and kitchen shears. I then filed with a regular ******* file (I bet it won't even let me say ******* file, but that's what it's called) and opened the end with a nail. It worked out great.
D(C) is offline
Old 12-11-07, 10:36 AM
draw line at carbon forks
goodall's Avatar
Bikes: Cannondale CAAD6 w/ 105, Fuji Track Pro, Windsor Cliff 4900
$13, love 'em. https://www.performancebike.com/shop/...tegory_ID=4202
goodall is offline
Old 12-11-07, 11:31 AM
*****es love tarck
kemmer's Avatar
Bikes: so many
Originally Posted by goodall
Nice!
I do it with linesman pliers, but I put an old cable inner in the housing to keep it from getting smashed and mangled. Then I carefully work my way around the housing, making nice clean cuts till it's all done. Most of the time they turn out great, sometimes I have to do it again or clean it up with a file.
kemmer is offline
Old 12-11-07, 11:38 AM
affix pistol bayonets!
mediccody's Avatar
Bikes: Early-Mid 80's Peugeot Super Competition, 1981 Basso, Mid-80's Peugeot Course
Note: Regularly cutting cables and housing in the way that the original poster described may result in additional wear and tear on your wire cutters.
Personally, I finally caved and bought some cable cutters. They make nice, clean cuts on cables without needing dremel bits, mallets, or hack saws. As an added bonus they are pretty good at cutting housing, with only a little of work sometimes needed to clean up the housing ends.
mediccody is offline
Old 12-11-07, 02:48 PM
via hiptop
Bikes: wooden lightning, cyclepro conversion, varsity beater, nishiki conversion, fuji conversion
Deathhare, you are fast becoming my favorite devil's advocate.
iamarapgod is offline
Old 12-11-07, 02:57 PM
roll'em high
shants's Avatar
i typically just cut housing with normal wire cutters and then re-open the end with an awl. works really well.
shants is offline
Old 12-11-07, 06:53 PM
:jarckass:
deathhare's Avatar
woot!
Old 12-11-07, 07:07 PM
Sheldon Brown's posse
shogun17's Avatar
Bikes: BMC SL01, XtC, Rhythm GX and a frankenstein avalanche 2.0
Bench vice + side cutters. easy
shogun17 is offline
Old 12-11-07, 07:19 PM
Harbinger
xiamsammyx's Avatar
Bikes: IRO Jamie Roy, Old Araya fixed conversion.
reciprocating saw. easy.
xiamsammyx is offline
Old 12-11-07, 07:21 PM
Are we not men?
The small shearing edge on the bottom of my multi-tool's needlenose works great.
Zombie Carl is offline
Old 12-11-07, 07:39 PM
jon bon stovie
Bikes: bridgestone 400 fixed gear conversion, dawes touring bike (model unknown)
+1 dremel. incredibly clean cut
ernok1923 is offline
Old 12-12-07, 05:49 AM
Wolfman got nards!
In Absentia's Avatar
Bikes: '06 Bianchi Volpe, '09 Mercier Kilo TT, '08 Jamis Exile 29er
I just bite it in twain with my teeth, then file it smooth on my beard stubble.
Reason is a scoundrel, stupidity is direct and honest. –Ivan Fyodorovich Karamazov
Man's mind, once stretched by a new idea, never regains its original dimensions. –Oliver Wendell Holmes
In Absentia is offline
Old 12-12-07, 07:27 AM
Hahahaha twain.
I just use dikes (diagonal cutters).
I use them to cut all kinds of metal stuff all day at work, so why should this be any different?
skinnyland is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
