disc break +'s and -'s
Bikes: MTB Agressor for now.
I had trouble in the MTB thread, they seem to say all the other threads can help but they have not. For those commuters who use hybrid bikes with disc breaks. How long do the pads last for and how often do they need to be adjusted? how often do you replace the hydrolic fluid also? Any other maintanence things I need to know about? I live in washington and it rains 24/7 and my breaks just can't aren't as good as I need in the rain.
POWERCRANK addict
shameless POWERCRANK plug
Recommended reading for all cyclists - Cyclecraft - Effective Cycling
Condor Cycles - quite possibly the best bike shop in London
Don't run red lights, wear a helmet, use hand signals, get some cycle lights(front and rear) and, FFS, don't run red lights!
POWERCRANK addict
no rim wear so no rim replacement every 6 months
consistent braking no matter what the weather and roads are like
masses of power and great modulation
simple to setup, adjust and use
no hassle changing/removing wheels
no rim contact so no worries with out of true wheels
no grabbing or pads wearing so fast you have to replace every 2-3 weeks (wet, gritted roads)
Quoted: 16 Post(s)
Cheaper to buy new rotors than rims, and there are a few places where you can buy titanium rotors in various sizes and thicknesses to fit your particular needs. One of my neighbors got tired of replacing worn out rims 1-2 times a year, so he bought a World DBX and been happy ever since. Depends on the terrain and conditions you ride in before considering going to disc brakes and not all disc brakes are equal. If you live where it's hilly with a few steep grades or if it rains a lot with leaves and mud to ride through, then the advantages of disc brakes become more apparent and desirable for a daily commuter...if not then rim brakes is good enough.
Commuter
Bikes: Handsome Dog Titanium (Work) Santa Cruz Superlight (Play) Kona Stinky (Real Play)
I can't agree more. I go through rims at least 1 pair a year unless I clean them after every ride. I'm switching to discs very soon. And I'll be fitting brakes rather than breaks.
Quoted: 9 Post(s)
Liked 9 Times
disc brakes = good.
initial setup can be a bit intimidating, but go slow & read instructions, and it's all good.
After the initial setup, you shouldn't have to touch them for a looong time.
I'm running Hayes hfx-9 Carbon for almost a year, over 5k miles. Original set of pads! (metallic). And I have 52 stops on my 12-mile r/t commute, total load about 250lb. can't beat that!
they can scream like a banshee when wet, but that's okay. They are unnafected by weather & rain.
Cheers
Cheers
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
I just changed to disc only on front for the winter, so I'm not through my first set of pads yet.
I went with mechanicals; it looks to me like the Avid BB7 is a pretty well-regarded brake and it's a lot less crud to mess with; all I had to buy was a new wheel (which I built myself), the BB7 itself, and a new brake cable.
So far it's working great.
The brake does seem to chatter - sometimes it seems that it grabs and releases several times a second. This could be the studded tires though.
I didn't like the $20/set that Avid wanted for their pads, so I bought a couple of aftermarket pads off eBay for $6 each. I'll keep track of how many miles I get out of the factory pads vs the aftermarkets.
The only significant downside I've found to the discs is that they're noisy.
Work: the 8 hours that separates bike rides.
Bikes: Trek 5200
I'm not anti-disc brake, but this thread is missing disk brake minuses:
- Wheels tend to weigh more because they are build to accommodate more stress from braking.
- Disc brake wheels are usually (well, almost always) built to accommodate wide tires - so forget about running 23c... and this is more weight.
- Added weight for the disc brakes themselves.
- Fork is build to be stiffer to accommodate extra load from disc brakes, so the ride quality suffers, often by a lot.
That being said, if I lived in a rainy area, I'd definitely consider a disc braked bike as a commuter. Rim brakes chew up rims when it's wet, and rim replacement is a PITA.
Bikes: BiknBrian brand custom 26 inch commuter trekker, Cannondale F600 Single Speeded MTB, Nashbar Cro-Mo CX, some other bikes and parts that could be made into bikes.
I like disc brakes and would prefer them on my commuter, but my rim brakes are fine for now. One thing I hate about rim brakes is aligning the pads. One thing I like is that they need a small barrel adjustment only once avery few weeks, were as the BB5's on my MTB need fixed pad and barrel type adjustment almost every ride. On the other had my rim pads only last about six months, but the BB5 pads last at least a year.
POWERCRANK addict
- you can use any rim width you want to. I used/will use mavic cxp33 rims which are 17mm wide so, in theory, I can run anything tyre width from 18mm to 28mm with no problems. Once I'm ready to convert the nightmare bike from hell back into a 29" (=700=622etrto) then I'll use a 25~30mm rim and run 2.0~3.0" knobbliies.
- I'd say any weight change was minimal unless you're already using lots of lightweight parts.
- there are beefy, brutal steel db only forks and there are vertically compliant, yet laterally stiff CF db forks. It just depends on who makes them and what sort of build you're going for.
Bikes: Trek 5200
- I'm not 100% about increase/decrease of braking stress at the rim but as long as the wheel is well built then most normal spoke counts/weights/crosses should still work. No use once only 12 spoke radial rims please .
Well, I was making generalizations... sure, there are exceptions to all my points, depending upon how deep your wallet is. You can buy a lot of rims for the price of a carbon fiber disc fork. And not everyone can afford a custom wheelset to use a narrow rim with disc brakes.
Bikes: '08 Surly Cross-Check, 2011 Redline Conquest Pro, 2012 Spesh FSR Comp EVO, 2015 Trek Domane 6.2 disc
Quoted: 5 Post(s)
Liked 7 Times
I've heard the arguments for both sides, for and against disc brakes, in areas like the PNW. It's rainy much of the year and there's grit on the road, rim brakes will wear down your rims, discs are more effective in the rain, etc... Here's my take on it.
I put disc brakes in the same category as brifiters: Effective and spiffy, but you're screwed if they break while you're on the road. If you've got canti studs, a Paul neo-retro or touring canti outfitted with some Kool Stop salmons will stop you dead to mark, even in the rain. There's a pivot, a spring, and a straddle wire. Not a whole lot to go wrong with it, and not a whole lot you can't fix on your own without needing an engineering degree to understand.
"I feel like my world was classier before I found cyclocross."
- Mandi M.
- Mandi M.
This bike has disc brakes
https://www.orbea.com/ingles/interior...ilia=6&gama=13
POWERCRANK addict
No problems with toe in, toe out, third hand, fourth hand, cable length, cable angle, rim width, wet pads, dry pads, pad pads, etc.
Just pretty much drop in, dial in and go.
Anyway, sorry if that seems a little aggressive, but IMHO rim brakes suck and have to the biggest PITA to set up, maintain and use with any degree of safety never mind consistancy.
edit: sorry that was a bit of a rant - your wise crack about disc brakes being rocket science - hardly but hey it's almost the holidays so...woohoo!
Bikes: SS Surly Crosscheck; '91 Cannondale 3.0
Last I checked you could get a whole set of adequate mechanical discs at Performance for $70. They're Forte, so not as nice as Avid, but they work really well (i.e. do the trick) and are as cheap as buying a set of calipers.
Anyways, that's my dream winter commuter build. Only thing that build doesn't have that I would want is braze ons for rack and fenders on the rear. Oh well, that's why there's hose clamps!
DancesWithSUVs
Quoted: 7 Post(s)
For the OP:
I have a little over 8mi round trip commute,all hills,all weather. My commuter(Safari) also hauls groceries,and served as my polo bike for about 6 months. I got about 9months(no idea how many miles,well over 2K) out of the front pads. The rears are about 13 months old,and will be swapped any day now when I get my new tires. From what I've read,most sources suggest swapping hydro fluid every 2 years.
As for extra weight,from looking at stats and actually weighing bikes,discs prolly add about a pound to the bike. Not really an issue when you consider that most commuters also add fenders,lights,racks,computers,lock holders,etc.
C'dale BBU('05 and '09)/Super Six/Hooligan8and 3,Kona Dew Deluxe,Novara Buzz/Safari,Surly Big Dummy,Marin Pt Reyes,Giant Defy 1,Schwinn DBX SuperSport,Dahon Speed Pro TT,Brompton S6L/S2E-X
Bikes: Too many to list!
Your Questions:
Pad Life and Adjustment: This certainly varies depending on conditions, but I change my pads about once/year or less - really just when needed. Just like with a rim brake, you'll need to make slight adjustments as the pads wear.
Hydraulic Fluid: There is none with a mech set-up. On my mtbs, I do run hydros. You MAY need to replace the fluid every few years at most.
Once you go disc ..... well, you know the rest of the story.
... Brad
Bikes: 2003 Giant OCR2
I'm really not seeing the need to change rims twice a year. What kind of mileage would necessitate that? I expect it could be due to the actual brake shoes being used, particularly if the compound is extra abrasive, or perhaps for very thin, light road rims. But for heavier cheap-o rims and decent pads, averaging only 1k miles per rim seems crazy to me.
Kool-stops are fairly highly reputed for being gentle on rims, it seems. They're also pretty strong even in inclement weather. Switched to them a few months ago and am very happy so far.
DancesWithSUVs
Quoted: 7 Post(s)
A much more realistic scenario is something happening to your rim;either being knocked out of true or tacoed. If the rim is out of true,rim brakes are less effective,or can't be used at all if the rim is bad enough. I tacoed a rim once and had to limp home with my front V brake opened because it was useless. On a side note,if brifters are so delicate,then why do you see so many cross bikes racing with them?
not a role model
The only downside for a hybrid is a little bit of extra weight, and the added cost.
For a drop bar bike, there are still issues with amount of cable pull. I've found that to prevent rubbing the lever pull has to be significantly longer than with rim brakes. I feel like road disk brakes still need to be redesigned to be more sensitive, meaning they would require less cable pull for actuation. They're still usable, and you tend to get use to the extra pull required, but it's still less than ideal.
POWERCRANK addict
DancesWithSUVs
Quoted: 7 Post(s)
Avid makes road-specific BB7's for use with road levers. I've got them on 3 of my bikes and they work great. Problem Solvers also make pulley adapters that take up the extra cable. I used a set when I converted my old cross bike from cantis to V's and they worked great.
Plays in traffic
Bikes: 1996 Litespeed Classic, 2006 Trek Portland, 2013 Ribble Winter/Audax, 2016 Giant Talon 4
Quoted: 76 Post(s)
Liked 14 Times
Everything is in the adjustment. They can be adjusted so actuation begins with so little movement you have to be careful not to brake while shifting. Or they can be adjusted so that you have to get a good squeeze in before anything happens. Stroke length is also affected by adjustment--you can make it short or long.
Adjustment isn't difficult, but it takes a bit of messing around to learn how things interact.
A downside not mentioned above is rotor warp. Sometimes it seems you just have to stare at them real hard to warp them. This is particularly so with the Avid Roundagons that came stock on my bike. For my winter wheelset I went with the stainless steel ones from Delta. They stay true a little better.
Of course, in my case, swapping wheelsets with the weather doesn't help much either. I have a hard time removing wheels without pulling to the side a bit, and inserting the rear one while lining up the rotor with caliper while getting the chain on the cassette takes more coordination than I have.
