how often should I pump my tires?
I am used to riding cheap walmart ligh weight bikes so I don't know if this is common or not.
Is it normal for air to escape from the tires when you are not riding them? I left my bike alone for a little over a week because it was stormy outside... within that time the tubes went from 55psi to 25psi. I don't think it is flat since I bought thorn resistant inner tubes and I have only ridden it a few times since then.
My bike is a 1972 steal 24 inch, and I was wondering if the weight of the bike was causing this or if it was just a slow flat.
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,395 Times
#1: All tubes will lose air over the course of a certain amount of time. 55psi to 25psi in a week is slightly fast, but not uncommon. What tires are you using that prevent you from exceeding 55 pounds though? Even cheap 27" will usually go up to 80 PSI on steel rims with no hooked beads.
#2: Ditch the thorn resistant nonsense. You're only contributing to your wheel's rotational weight (forgot the 'offical' term for this) - right where the least amount of weight counts the most.
#3: Weight of your bike is not important to tire pressure loss.
#4: Check your tire pressure always before heading out. It is not unusual for a tire at 120PSI to have deflated to 110 or 100 over the course of a day or two. 95% of the time, you will have to give the tires a bit more pressure before heading out.
#5: You do have a tire PSI gauge, correct?
-Kurt
-Kurt
-Kurt
-Kurt
Bottecchia fan
Bikes: 1959 Bottecchia Milano-Sanremo (frame), 1966 Bottecchia Professional (frame), 1971 Bottecchia Professional (frame), 1973 Bottecchia Gran Turismo, 1974 Bottecchia Special, 1977 Bottecchia Special (frame), 1974 Peugeot UO-8
Quoted: 33 Post(s)
Liked 12 Times
The heavy Walmart stuff usually holds air pretty well but I'd have to agree with what Kurt says except maybe for #2. I don't mind fixing a flat and prefer the lighter weight but if you really don't want to have to fix a flat on the side of the road and aren't going anywhere in a hurry then it might be worthwhile. Some ultra-light tubes can loose air in a hurry but you won't find those at Walmart. Get yourself a good floor pump, a frame pump, and a patch kit. They're worth every penny.
1959 Bottecchia Milano-Sanremo(frame), 1966 Bottecchia Professional (frame), 1971 Bottecchia Professional (frame),
1974 Peugeot UO-8, 1988 Panasonic PT-3500, 2002 Bianchi Veloce, 2004 Bianchi Pista
Liked 10 Times
Check your pressure before every ride. It just takes a minute. I'm in AZ for the Winter, and have not had a flat in two Winters. I ride fairly lightweight tires/tubes. This year I'm riding Veloflex/latex, so far so good.
When you say you are riding 24", do you mean the tires, or the frame size?
Is this a road or mtn bike?
24" tires. I certainly don't want to have to fix a flat, The reason I got my bicycle was because I don't want to wander around certain areas alone. I don't live in the safest areas, and with a few sex predators living pretty close by I don't want to be stranded anywhere.
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
I rode a MTB less than 3 miles in Arizona (not far from Sedona) and had two flats. If you've never ridden there, you have no idea how pervasive and nasty goathead thorns are. Gammerus, do what you have to to keep from getting flats. With skinny 24" tires, it doesn't take a lot of air to result in that kind of a pressure drop. If they were leaking from a hole in those tubes, you'd be able to see it.
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
Yes you will need to add air before every ride...most of the time. I have some bikes that the tubes seep air faster than others. Not sure why. Also if I am not positive but if you ride every day they seem to hold their pressure a bit longer than if only ridden occasionally, or maybe it just seems that way.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Bikes: Full Dura Ace Cannondale. 3 speed touring bike
Get a good hand pump with a gauge, pump up tires to recommended pressure every time you ride
Disraeli Gears
Nobody has offered the advice to dip the wheels (fully inflated) in water, such as a bathtub or kiddie pool, to check for a slow leak. Sometimes the valve cores of Schrader valves (the kind that look like those on an auto) leak because they're not screwed in tight enough. So you should check the valves too -- but that can be done with spittle.
You may be able to get tires with kevlar belts built-in -- dunno much about 24 inchers though -- and those will help prevent goathead flats, in my experience. The problem with tires is that light weight and flat-resistance are pretty much mutually exclusive.
Bike Junkie
Location: South of Raleigh, North of New Hill, East of Harris Lake, NC
Bikes: Specialized Tarmac, Specialized Roubaix, Giant OCR-C, Specialized Stumpjumper FSR, Stumpjumper Comp, 88 & 92Nishiki Ariel, 87 Centurion Ironman, 92 Paramount, 84 Nishiki Medalist
Quoted: 68 Post(s)
Liked 37 Times
Here's a tip to save some air pressure loss when using Schrader valves like yours. Go to an auto parts store. Purchase the chrome/alloy metal tire valve stem covers designed to be used for mag wheels then replace the black plastic covers the tubes came with. These chrome/alloy tire valve covers have a small gasket that seals the Schrader valve and prevents small leaks from the valve. I tried this on my mountain bikes and found pressure loss over time was cut by one third.
Keep in mind, the pump you are using reduces the tire pressure when you place the pump head on the tire to inflate it. Try pumping up the tire pressure to 55PSI. Disengage the pump from the tire. Now re-engage the pump and read the pressure shown on the guage. You probably lost 5-10PSI. I use the same type of auto pump and found it takes a few PSI to fill the tube from the pump to the guage. Auto tires have much larger volume, that's why the small amount of air loss does not affect them. So I don't think you actually lossed 30 PSI, more like 20 to 25.
Roccobike BF Official Thread Terminator
Bikes: '86 AMBROSI / C RECORD. PINARELLO MONTELLO / FRAME, FORK.
Disraeli Gears
The concept of gun control in the USA (apparently): prying the "piece" out of the cold, dead hands of the wacko who just snapped, slaughtering [pick some number] innocent people, including children. Individual freedom carried to its illogical, anti-socialist conclusion.
Bikes: Bruce Gordon BLT, Cannondale parts bike, Ecodyne recumbent trike, Counterpoint Opus 2, miyata 1000
Personally, if I have to add air to my tires more then once a week before I pedal to work, I check the tube for leaks.
Bikes: Swift folder, single speed
30 lbs./week = leak. Take off the wheel and the tyre. Inflate the tube. Look for the leak. If you can't find it, do like the man said, put it in water, like your bathtub or a bucket, and see where the bubbles are coming from, and then patch it up. Carefully (!) run your fingers around the inside of the tyre to feel for anything sharp that may have caused the puncture. Cactus thorns flatten my pickup truck tyres, too. Don't be afraid of guns. They are an invaluable tool and they have saved countless lives.
