Iro btm bracket
Bikes: 1958 raleigh fixed , specialized P2, standard S250, giant cross country bike
Iro btm bracket
im in the market for a bottom bracket thats goin on a iro mark V. (doesnt need to be anything fancy)It will be matched up to a track hub spaced at 120 any one know the size btm bracket i need to get my once again perfect chain line?
Guest
Posts: n/a
Quoted: Post(s)
That 110mm spindle is too long for 75's not to mention the wrong taper...you need a Sugino superlap BB. I think they're 107mm and ISO NOT JIS taper.
yo yo yo yo yo
109 symmetrical iso for 75s..
see here for track cranks: https://www.businesscycles.com/tr-refspec.htm
road cranks probably a 107 or 103 depending on chainstay clearance
a set of purely gangster bullet proofs!
lol
lol
fails just as quickly
It looks like this should give you the information you need.
For a 42mm chainline, you could use a 111mm spindle with the ring on the inside of the spider. (someone check me on that?)
For future reference, chainline measurements have everything to do with the type of cranks, bottom bracket and hubs. The frame is not a factor.
ahhh yes that quick fix that should hook me up i do believe thank you kind sir
extra bitter
I don't think 111mm is available in anything reasonable (Campy makes one, but fughedaboutit). A 109 or 113 should be close enough, assuming it's symmetrical.
